fill hole
/ fill hole #1
jinmared
Goldendale,Wa
Jinma 354 fwd
I have a 354 Jinma 4WD tractor , where is the fill hole for adding lubricant to the front transfer case? I found the drain (no brainer) but I sure cant find the fill plug.
thank you
/ fill hole #2
thank you
If you mean front drive, I'd expect to find three drains; one below the center of the differential housing, and one each under each drive hub. As far as filling it, I'd expect to find a vent on top of one of the axle housings. Unscrew the vent to fill.
Because there is no "front transfer case". The only transfer case is under the transmission, and it's gravity-filled through the transmission housing.
//greg//
/ fill hole #4
Those are some great pics and references! Big props to you. I am going to paint all mine red now! I am printing them out and putting in my "manual of stuff" I keep collecting.
There needs to be a book, chinese tractor repair for dummys.
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2013 Ford F-450 Reading Service Truck (A61573)
2013 Ford F-450...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
