fill hole
/ fill hole #1
jinmared
Goldendale,Wa
Jinma 354 fwd
I have a 354 Jinma 4WD tractor , where is the fill hole for adding lubricant to the front transfer case? I found the drain (no brainer) but I sure cant find the fill plug.
thank you
/ fill hole #2
thank you
If you mean front drive, I'd expect to find three drains; one below the center of the differential housing, and one each under each drive hub. As far as filling it, I'd expect to find a vent on top of one of the axle housings. Unscrew the vent to fill.
Because there is no "front transfer case". The only transfer case is under the transmission, and it's gravity-filled through the transmission housing.
//greg//
/ fill hole #4
Those are some great pics and references! Big props to you. I am going to paint all mine red now! I am printing them out and putting in my "manual of stuff" I keep collecting.
There needs to be a book, chinese tractor repair for dummys.
NISSAN FORKLIFT (INOPERABLE) (A60736)
NISSAN FORKLIFT...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 DRAGON ESP...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Case SV280B (A60462)
2019 John Deere 1023E Tractor (A61166)
2019 John Deere...
