fill hole
/ fill hole #1
jinmared
Goldendale,Wa
Jinma 354 fwd
I have a 354 Jinma 4WD tractor , where is the fill hole for adding lubricant to the front transfer case? I found the drain (no brainer) but I sure cant find the fill plug.
thank you
/ fill hole #2
thank you
If you mean front drive, I'd expect to find three drains; one below the center of the differential housing, and one each under each drive hub. As far as filling it, I'd expect to find a vent on top of one of the axle housings. Unscrew the vent to fill.
Because there is no "front transfer case". The only transfer case is under the transmission, and it's gravity-filled through the transmission housing.
//greg//
/ fill hole #4
Those are some great pics and references! Big props to you. I am going to paint all mine red now! I am printing them out and putting in my "manual of stuff" I keep collecting.
There needs to be a book, chinese tractor repair for dummys.
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Massey Ferguson 9250 (A63688)
Massey Ferguson...
