fill hole
/ fill hole #1
jinmared
Bronze Member
Goldendale,Wa
Jinma 354 fwd
I have a 354 Jinma 4WD tractor , where is the fill hole for adding lubricant to the front transfer case? I found the drain (no brainer) but I sure cant find the fill plug.
thank you
/ fill hole #2
thank you
If you mean front drive, I'd expect to find three drains; one below the center of the differential housing, and one each under each drive hub. As far as filling it, I'd expect to find a vent on top of one of the axle housings. Unscrew the vent to fill.
Because there is no "front transfer case". The only transfer case is under the transmission, and it's gravity-filled through the transmission housing.
//greg//
/ fill hole #4
Those are some great pics and references! Big props to you. I am going to paint all mine red now! I am printing them out and putting in my "manual of stuff" I keep collecting.
There needs to be a book, chinese tractor repair for dummys.
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A62129)
2020 CATERPILLAR...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2017 JOHN DEERE 350G LC EXCAVATOR (A62129)
2017 JOHN DEERE...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
