Ferris scalping
/ Ferris scalping #21
Add wheels to the frame, preferably with adjustable heights in case you get it wrong the first time. Weld the mounts to the tool's frame.
/ Ferris scalping #22
I have a IS700z, so not true IS like yours. I mow at 3.25", and was having some scalping issues..leveled the deck and found it WAY off, especially on LH side that seemed to scalp the most. That took care of mine, and adding in 1/4" of pitch also helped it stripe a little better.
/ Ferris scalping #23
Looks like you are making a couple laps around the lawn to have room to turn around and mowing across the lawn do do the rest. It looks like you are turning right where the slope from the road levels out with the lawn so your deck is hitting the edge of the slope. Maybe try making another lap or two so you are turning on completely level ground.
/ Ferris scalping #25
A low tire will also give you some scalping on turns. At only 12# on my rear tires, it doesn't take much to allow scalping to happen.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
1 TIRE BALANCER (A66091)
1 TIRE BALANCER...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
