Ferguson hydraulics
/ Ferguson hydraulics #1
genebogart
ferguson to 30
I'm thinking about buying a ferguson to 30. Is there anyway to get hydraulics off the pump on the tractor itself to operate hydraulic powered attatchments. Like a hydraulis tiller or a plow on the front?:confused:
/ Ferguson hydraulics #2
:welcome:
There might be a way to operate a one-way hyd cylinder by locking the 3 ph arms and plumbing off the rockshaft (could do that with the 8N Ford, but not sure with the TO-30).
Doubt a hyd tiller is possible however.
On my TO-30, I ran a cable from the 3 ph lift arms to the front plow and raised it that way. Took a few cable pulleys to do it, but it worked ok for me until I could upgrade the tractor.
/ Ferguson hydraulics #3
I don't believe that those tractors had much for extra reservoir volumn (the amout of fluid that can leave the tractor without causing issues). The popular setup on those was to mount a pump to the front of the motor.
Thanks the cable pulleys sound like the easiest idea, i thought about a hydraulic pump powered by the pto?
wouldnt i need a resevoir then?
/ Ferguson hydraulics #7
Actually, it is very simple to develop a hyd source for cyl or hyd motors. There are the clutch hyd pumps, and there are pumps like this which I use on my PT for lift and steering.
This little pump can run off the fan belt and provide up to 3 GPM, at 3000 psi.
You would need a small reservoir, a valve with relief, a pump, hoses, hoses fittings and some know how.
https://www.surpluscenter.com/item.asp?item=9-4199&catname=hydraulic
Git er done
2007 Ford F-150 Crew Cab Pickup Truck (A61573)
2007 Ford F-150...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2012 International (A59230)
2012 International...
John Deere 7410 (A64119)
John Deere 7410...
2025 Tooth Bucket Mini Excavator Attachment (A61572)
2025 Tooth Bucket...
2011 Ford F-250 Pickup Truck (A61573)
2011 Ford F-250...
