Fencing brace-post pulling up during install ... Suggestions?
/ Fencing brace-post pulling up during install ... Suggestions? #21
adding on to SandburRanch statement.
create a DIY mesh tightener....
two 2 x 6's one on each side of the wire mesh fence.
use bolts and nuts, with washers to bolt the 2x6's together sandwiching the wire mesh.
then wrap a chain or like, around center of the 2x6's and tighten the wire mesh.
the 2x6's, help keep the wire mesh from being distorted as you tighten things up.
it gets a little tiresome, dealing with about 8 plus bolts per each section. but *shrugs*
I'm pretty sure that's exactly what he's using, based on the diagram. Well, 2x4's instead of 2x6s. Two come-a-longs is standard practice. I'm really thinking the problems is coming from the fence pressure, not when stretching. But I may be wrong. That makes a big difference, but there should be zero pressure on the post that's raising up until the pressure is released from the come-a-longs.
Edit: Never mind, I was over looking a vital piece of the diagram. Now I see how it's happening while stretching. The only thing it can be is that both of the post needs set better. Make sure you go back and add those other (blue) brace wires before finishing up as well, or you'll have a lot more pulling up in a years time.
I think your problem is you are attaching the fence to the left post when pulling to the left. The fence should be fastened to right post when pulling the fence to the left.
Both post-coming-up problems occurred before the fence wire mesh was ever actually attached - The come-alongs alone were still holding it.
In my diagram, the item labelled "2x4's CLAMPED ON TO WIRE" is our equivalent of what you described. It's just that we used 2x4's rather than 2x6's. We're using five 1/2" diameter bolts thru them, & we crank them as tight as we can get them to hold the wire tight. Do you think the 2x6's would help over the 2x4's?
Also, I seem to remember that Red Brand's own instructional videos shows their installer using two come-alongs, one at top & one at the bottom ... will have to go re-check that. But I do see what ya'll are saying about pulling un-evenly.
/ Fencing brace-post pulling up during install ... Suggestions? #24
Ah, I see, my bad - I was not exactly understanding the problem you were having...
What you need is a wire from the top of the left post (where the blue wire attaches) to the bottom of the temporary post. Sort of parallel to the red wire. That will allow the temporary post to act as the end post - the left post and the red wire will brace that end of the fence once the mesh is attached to the left post.
(I say "wire", but since it's temporary, a chain and another come along would probably make more sense.)
/ Fencing brace-post pulling up during install ... Suggestions? #25
Anything that’s attached to the temporary post isn’t a solution. Though it’s happening while tensioning, it will continue to happen from the tension of the fence.
/ Fencing brace-post pulling up during install ... Suggestions? #26
Anything that痴 attached to the temporary post isn稚 a solution. Though it痴 happening while tensioning, it will continue to happen from the tension of the fence.
I think this was addressed to my post? If so then with the setup shown, during tensioning all the force is being applied to the top of the left post. This in not the case once the fence is attached top and bottom to the permanent post.
The idea is to tension the fence, then attach it to the permanent posts. Everything that is temporary or attached to anything temporary can go away once the fence is fastened to the permanent posts.
/ Fencing brace-post pulling up during install ... Suggestions? #27
Actually, that force will still be there. It never goes away unless the tension in the fence is gone.
/ Fencing brace-post pulling up during install ... Suggestions? #28
If the fence is only attached to the top of the permanent post, then you are correct. If the fence is attached to the permanent post correctly, the force will be distributed along the height of the post. That is not the same as the force(s) being applied while tensioning with the setup as shown. With that setup, while tensioning, there is no force on the lower part of the permanent post, so the permanent horizontal post will tend to act as a "hinge".
Un-even comealong tension. The top one is tighter. Use only one centered to solve the problem.
I understand the un-even tensioning idea, but I re-watched Red Brand's installation videos (Installation Videos), & they use a come-along at both the top & bottom.
/ Fencing brace-post pulling up during install ... Suggestions? #30
I do see what you're saying. But still, the pressure won't go away, though it will be distributed from top to bottom. Bottom line is that everything thing is braced properly. I would re-tamp both of those brace posts. If either one moves, you'll get heaving posts.
Since Red Brand's installation videos say to do it this way, in the beginning we had the "TEMPORARY 4x4 HORIZONTAL BRACE" higher than the "PERMANENT 4x4 HORIZONTAL BRACE", so it was higher than the fence wire & therefore out of its way, but when the left brace-section post started coming up, we thought the "TEMPORARY 4x4 HORIZONTAL BRACE" was pushing the top of the left brace-section post to the right too hard, making the left brace-section post sort of pivot around the "PERMANENT 4x4 HORIZONTAL BRACE" ... so we lowered the "TEMPORARY 4x4 HORIZONTAL BRACE" to be lower than the "PERMANENT 4x4 HORIZONTAL BRACE" & re-tensioned. Again, it helped, but the left brace-section post still wants to come up.
The entire fence length is 1,315 feet, and this problematic brace section is at about the 1,150' mark, meaning we're almost at the end. So ... I think we can live with this "almost tensioned enough" section if we have to. What really concerns me is that there's only on more brace section to go ... The End one :shocked: If the final post(s) wants to come up/ out, there's no more additional fence beyond it that we can rely on to counteract the pulling to the right ... So we gotta get that one solid on its own.
At the fence end, I think I'm going to add a second brace section so I have two brace sections in a row, & install both the red & blue criss-crossing wires on both sections. I wish I had concreted these last two or three posts in. Maybe I should pull 'em up & do that ... :confused:
Wow ... Long thread for a little fence post pullin' up situation :laughing:
/ Fencing brace-post pulling up during install ... Suggestions? #32
Right, absolutely - the tension never goes away, that's what keeps the fence tight. All you can do is try to distribute the forces equally and transfer them as much as possible to an immovable object. In this case the "immovable" means applying the force horizontally at the ground level of a buried post.
But let's also remember this is also the ideal scenario, where everything is flat and level. A slight rise of elevation to the right of the diagram can really throw a curve ball at this. Ask me how I know... :D
/ Fencing brace-post pulling up during install ... Suggestions? #33
He he.. It ain't rocket science, but it ain't always obvious either. Took me a while to get it through my head that when it comes to fencing, a little extra work at install time pays off in the long run... :thumbsup:
I had that happen with railroad ties used as fence post, and did not understand it at that time.
The brace post should be braced against undisturbed ground. Could also add a 12 in long and 2 x 6 in wood bottom brace vertical in the hole for the brace to butt against.
I think I see what you're saying ... Jam a piece of wood in the post hole between the post & undisturbed ground. That would probably help. In the end, I suspect that if I poured in concrete instead of just tamping the dirt real well, I could probably tension the wire with just about all my might.
/ Fencing brace-post pulling up during install ... Suggestions? #35
Yep, I know hills pretty well too. :D
/ Fencing brace-post pulling up during install ... Suggestions? #36
Actually, it IS rocket science. You need to do a moment balance around the main post at ground level. Then you will see that there is nothing counteracting the MOMENT created by the wire force times the distance from the top of the post to the ground. To counteract this moment you need a diagonal to push or pull against the top of the post. You can't push on a wire but you can push on a post (or actually a 4x4) set from the base of the 2nd last post to the top of the last post. OR, you can set another post and tie a wire from the top of the last post to the base of this temporary post (or stake). Otherwise, all you've done is created a solid square structure that can 'match-box'. Sort of like a table that you can tip over by pulling from the top. You need to use a counter measure to resist the tipping force. This tipping force can NOT go thru the last post at ground level.
Draw a 'free-body' diagram and that will show you what I mean.
/ Fencing brace-post pulling up during install ... Suggestions? #37
You're over thinking it. Fences have been braced like this for as long as fences have been built. Keep looking at it and you'll see why it works. It's all there.
/ Fencing brace-post pulling up during install ... Suggestions? #38
For this problem post, drive a T-Iron post at 45ー (that's 45 degrees) down 5 ft. as a dead man and twist a brace wire from the bottom of the dead man to the top of the heaving post. In the pic that would be to the left. On some long sections a double dead man may be required. One for the corner post and one for the brace post.
When you get to the last set of braces do the same even though one dead man may be on the Doberman's side.:laughing:
/ Fencing brace-post pulling up during install ... Suggestions? #39
I'd guess posts not tamped as good as they need, or as deep as they need for that span of fence. Growing up, never got to leave the post unless we ended up using ALL the dirt dug from the hole to fill back in around the post. We tended to use 10'+ posts, 5' in, 5' out for the 1st post in the line, maybe a smaller one for the 2nd brace post. You're alot tougher on a set of digger handles than I if you can dig them faster than the Danuser...
Smooth posts will pull worse than the hedge posts we used, might consider driving a spike through them in a place or two.
Other thing I'd say is brace maybe not as long as it could be. Steeper brace wire tends to pull post worse.
Never went to the effort of setting another post to pull out just to stretch the fence with. When we ran woven wire, used a pull board like you have. We'd hook the 8n Ford on the wire, and in 1st gear at a low idle, would let it pull until it spun or died. Then we tied off the fence. On flat ground that was about right, had to leave more slack on hills.
Didn't read all of this, but might help you some:
http://www.mbforagecouncil.mb.ca/Fo...acilities/10-6 Brace assemblies-BC Agric.pdf
/ Fencing brace-post pulling up during install ... Suggestions? #40
I know what is happening, only because I had the same problem.When tensioning ,go slow. Tension about half then wait for the "wave" to settle down.You are pulling on a spring and if you pull too fast the tsunami hits the other end with a multiplied force.Remember there is something as too tight,you only want to take out half of the kink found in the horizontals.The compresion brace is prettier horizontal but is usually only used when you have too because of through drilled wires.It will work better if the compression is directed to the ground.or for excample at the last post from the top of last to bottom of second last and mid braces would need two from the centre top to the bottom of each next post.Hope this helps.
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
JLG 600 AJ SKYPOWER BOOM LIFT (A60429)
JLG 600 AJ...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
