FENCE QUESTION
/ FENCE QUESTION #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Need to build several fences with livestock on both sides. Usually will be sheep but on occasion med. & full size cattle. Is it good/bad idea to alternate posts on either side of fence with fence down middle?
/ FENCE QUESTION #2
Wire and T-Posts or something else? With wire and T-Posts, I really don't think it will make much difference in the strength of the fence. I have never done that on any of my cross fences and they seem to hold up fine. Trees are harder on them than the cows (we have Longhorns and Angus). I do see where it will make it hard on you, weaving in and out while pulling the wire.
/ FENCE QUESTION #3
I've seen it done that way but we never have and the fences have been just fine.
Some people think it is an advantage, though.
/ FENCE QUESTION #5
Just make sure you put equal #'s of animals on each side of the fence and it will all equal out. I heard that up north MN there is so much iron ore that the sheep give steel wool. Really!
/ FENCE QUESTION #6
This summer I put up about 110' of cattle panel to separate a cow pasture from a goat pasture. I alternated the posts. I found that when the animals lean on the fence the panels bend into an S shape, and I've had them pop their clips. If I were to do it again (and I may) I'd put all the posts on the goat side.
/ FENCE QUESTION #7
In general, the wire goes on the same side as the animals. This way if animal leans or pushes on fence, the wire is less likely to be knocked off the post. With animals on both sides, I guess weaving the wire is OK but probably more work since the guy tying or stapling the wire will have to work from both sides of the the fence. Cattle will push harder than sheep on the fence and maybe the wire should be on the cattle side.
/ FENCE QUESTION #8
I put up 1000' of field fence (hog wire) along the back of our property. My neighbor already had up 5 strands of barbed wire. I placed an additional T-post where need to hold the fence up or down. So I basically have my wire on the back of his post. I used 12 ga. electric fence wire to wire the field fence to his T-post and nailed to the back of his wooded post. Saved a lot of money in doing this.
With the cost of fence on the rise, I would recommend a good electric fence charger (low independence) and 12 ga. electric wire (harder to break). This will keep the goats, sheep, horses, cows, or whatever you put in the pastures off that expensive fence.
BTW. I have goats and they push/lean on the fence more than any cow I've ever seen. I always make sure that I put a couple cattle panels somewhere along the fencerow for them to rub on. It makes them happy.:D
Chris
/ FENCE QUESTION #9
I have cattle and equines behind wire / tpost fences.. thus some on wire side.. some on post side.. never noticed a problem...
soundguy
/ FENCE QUESTION #10
Whatever animal there is the fence will lean to whichever side is greener. :D
Make it easy on yourself building it and put the wire on the cattle side (they have more weight to push around).
/ FENCE QUESTION #11
agree, keep it simple... one side...goes up faster and end the end the additional labor of crossing is not worth it!
/ FENCE QUESTION #12
Incentives like barbs and hot wires also help.
soundguy
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
More info coming soon (A64557)
More info coming...
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2006 Heil DOT 407 Aluminum 9,000 Gallon Ethanol T/A Tanker Trailer (A64194)
2006 Heil DOT 407...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
