Fence Posts, upside down or not?
/ Fence Posts, upside down or not?
It's been over 8 years since I started this thread and we have reached no consensus yet. The poles I have driven in upside down 8 years ago are still holding strong even in the swampier areas where I have put them. My neighbor put a fence down last year using 4x4 treated posts. He dug a large hole, placed the pole then poured a bag of concrete mix in each hole leaving the concrete to set with the natural moisture in the ground. All of his posts are already loose and leaning.
/ Fence Posts, upside down or not? #32
FWIW - the standard sizes of T-posts are - 101, 125 & 133. They use to make 145 also. I can't find 145's - guess there is no market for these bigger posts. The number designates the weight of steel per lineal foot of post.
/ Fence Posts, upside down or not? #33
I have dry bagged a good number of posts. I always "poke" the dry mix with a piece of 1/4" rebar to get the air out as good as I can then have at it with about a one inch pry bar and finally take my bar with about a two inch diameter knob on one end. I then backfill the soil a shovel full or two at a time tamping with the two bars. It may take some time but my posts stay in pretty well.
This past summer, I pulled some 4x4 posts that I had used for a fenced in yard for our dogs that needed some changes. I had set them the same way. I pulled them or at least tried to with one of those lever style pullers that works with a t-post or a wood post with a chain. This was before it got so dry around my neck of the woods and those posts would not budge. That's even with hanging my post pounder on the lever for extra "leverage". I ended up digging up a bit of dirt to make a little pond area and filling it with water several times. Finally I was able to slip the posts out leaving the concrete behind.
Anyway, the upside down theory sounds plausable. I never noticed premature rotting and I like to put the larger end in first thinking the taper helps to hold the post better?
/ Fence Posts, upside down or not? #34
I have always seen post put in large end down when putting them in a hole, small end down if driving them. I have no idea how longevity is affected by either method.
Telephone / utility poles are always installed large end down. I would think that as many as they install, they would know the best way. They would sure look strange if installed upside down.
/ Fence Posts, upside down or not? #35
There is a correct answer. If using a hydraulic post pounder and pounding them in, install them with the narrow end in the ground. The reason is, it is like putting a cork in a bottle. They get tighter as you drive them in.
If augering or digging a hole, they go in fat side down.
/ Fence Posts, upside down or not? #36
It just hit me. I've seen many, many semi loads of those green, turned fence posts. There is a pointed end and a squared off end, but both ends are the same diameter. I've always thought you put the pointed end down. Whether driven or put in an augured hole.
/ Fence Posts, upside down or not? #37
Never seen posts pre sharpened
/ Fence Posts, upside down or not? #38
Now - that's just darn strange, buckeye farmer. I've never seen anything BUT the "green" pre-sharpened ones. They are loaded up into bundles of, probably, thirty or so and then these bundles are stacked up on a semi-truck. The semi - loads are always going west. Over to the "wet" side of the state. Lots & lots of semi loads - going west in the spring and again in the fall. Softer ground - easier pounding, I would guess.
NO - on second thought - I've seen posts that weren't green nor pre-sharpened. A guy up north - around Colville - was cutting and setting posts. They were small Tamarack trees from right off his property. And when I ran the T-posts & barbed wire here on my property - there were three posts. Looked like Locust. Still standing on my property line.
So when I fenced my 80 acres in 1982. 650 - T-133 steel posts and three wood posts. The three wood posts are all that was remaining from what the original homesteader installed in 1892. These three posts are still on the fence line - strong as ever.
/ Fence Posts, upside down or not? #39
Utility poles are pressure treated, with the treatment refreshed occasionally. They also are taller than the average fence post, and carry a lot more top weight.
Having said that I was told by a landscaping instructor in my past life to put the top up and the bottom down, so that precipitation would run off rather than down into the poles. That's also why we cut post tops at a slant.
Decades ago my father built a 20x93 foot wooden greenhouse using 4x4 posts every 4 feet set into the ground, and pouring concrete into the holes. The following spring he dug all of those posts back up and removed the concrete with a sledgehammer, as the frost had caught on the concrete and lifted them out of the ground.
/ Fence Posts, upside down or not? #40
We lived in Glennallen, AK for a year. It's between Anchorage & Fairbanks. The utility companies would put a multi-layer sleeve on their poles when they set them. Several layers of some type of plastic sheeting. The idea - the frost would attach to the outer most layer and just slide it up/down on the inner layers - with the seasons.
Must have been of some benefit - it was used on all their poles.
2011 BIG TEX 40 GOOSENECK (A60736)
2011 BIG TEX 40...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
2018 FORD TRANSIT 350 4X2 CARGO VAN (A59906)
2018 FORD TRANSIT...
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
