Fence corner brace question
/ Fence corner brace question #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
One method of securing cross brace to corner posts is to use galv. rods. I did the first one with available 3/8 rebar. Any long term problem with this alternative?
/ Fence corner brace question #2
I've used them but prefer the end plates that Tractor Supply sells. I expect that either will last longer than the brace itself.
/ Fence corner brace question #3
I have used the galv. rods with good results. Using rebar really depends on what kind of chemical treatment was used on your post.
/ Fence corner brace question #4
Oops...Mudcat's right....if you are using treated wood you need to be using galvanized materials. I've seen treated wood eat non-galvanized nails in as little as 3 years.
/ Fence corner brace question #6
Originally treated lumber wasn't as hard on iron products. Then they went with a new more evironment friendly product that ate everything but stainless or hot dipped galvanized. That has been replaced now with a newer version that's still more kind to the environment and not as harsh on steel.
I would still go with galvanized or stainless. But not because the treated lumber with destroy iron or steel fasteners.
/ Fence corner brace question #7
dmccarty said:
Was the wood wet or dry? Does it matter?
It was above ground, outside, so it got wet when it rained, but I don't think that matters....Harv pretty much said it all.
Mike
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
2022 EZ-GO ELITE...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
(5) Texas Built 25' Stand Alone Livestock Panels (A66408)
(5) Texas Built...
2022 TRAC MV (A65643)
Bobcat Turbo 873 Skid Steer (A62679)
Bobcat Turbo 873...
