FEL's
/ FEL's #1
John47
Missouri Ozarks.
Yanmar FX235
I have a FX235 and I'm in the market now for a FEL. Whats the best make and the model number that fits my 235?
/ FEL's #3
Get the Koyker 125 loader made for the F215 = fits like a glove with their mounts
If you get the 120 it will hit the front tires
Ernie Imports
/ FEL's #4
Hey John, I've got a Koyker on my F16D. Fits the bill for me. Your welcome to come and look at it. And I'll give you info on the place that I got the best deal.
/ FEL's
I'm still not driving yet Ronnie, fear is if I get a flat tire on these roads, I may not be able to change it myself safely.
Anyway, let me know where you got your FEL from and I'll look into it.
Thanks Ronnie and to you Ernie!!
John
/ FEL's #6
This is what it looks like with a Frey.
Buck
/ FEL's
Ernie, a question. When I get a loader and fit it to the FX235, where do I tap into the hydraulics?? I noticed while I was greasing today, that there is a block under the right side deck, (when sitting in the seat). There are two steel pipes with "banjo" fittings to this block, is that the "tap off" point for the pressure side??
Most of the hydraulic lines are on the left side of the tractor on the same side as the hydraulic filter.
/ FEL's #9
John, We are receiving a load from Koyker today. And the tractors will be here any day now.
When I mount the loader on the 235 I will take pictures & post them here for you along with all the details.
Ernie
/ FEL's #10
Buck
Buck,
I like the way the Frey bucket is tucked in close to the front tires
I have always wondered why ALL loaders arent built that way.
It sure makes the tractor a lot more stable.
/ FEL's #11
I also saw how close the Frey bucket was to the front of the tractor and I'll second Ernie's last comments. The closer the bucket is to the front axle, the lower the weight transfer on the front axle. The Koyker on my tractor has the bucket mounted out far enough it equals the wheelbase. Every pound in the bucket is 2 lbs on the front axle.
/ FEL's #12
I have looked at the frey loaders also, But Frey tells me they do not make the mounting brackets for yanmars. Buck are you making your own brackets?
thanks
Mark
/ FEL's #13
tractorErnie said:
Buck,
Wow Buck, just like Ernie (and Mickey) I saw an immediate and advantageous design in Frey's loaders. With their bucket fully flat and on the ground it's quite obvious that their front loader arms are nearly at 90° where most other manufacturers are at the lazy 45°.
If you're not quite sure of what to look at, check out the length and orientation of the dump/curl (front) hydraulic rams!
Mark
/ FEL's #14
When I purchased a FEL from EFC for my F18D, Buck was selling pricipally Koykers. Because of the reach of the arms, there was some concern about load lifting capacity of the rig. So, Instead of installing a Koyker 120 (I think that was what was recommended by the manufacturer) he fabricated new brackets and installed a much shorter Koyker 80. Works fine, and has the additional (and more impotant) benefit of providing more room for my knees and feet. (I'm 6'6" tall and have size 15 shoes --"a good understanding"):p
Frank
/ FEL's #15
thanks
Mark
After installing Koyker’s I truly appreciate the Frey loaders. We do build our own brackets for the Frey but we were building our own brackets for the Koyker’s anyway. On average we could get the loader 6" to 12" closer to the tractor if we built the brackets in house. With the Frey we can get the bucket even closer than that. maybe as much as 6 more inches. The only parts we were using from Koyker was the loader and bucket. Our hose kits are built in house and we use an American valve that has a lifetime warranty and that will stay the same with Frey.
For me it is not about increasing lift capacity so much, it is about limiting the stress the front axel has to endure. Also like you already know most of what we sell does not have power steering so the closer the better.
In a few weeks we will be mounting the new Vertex high lift Frey loader on our new Deutz 80 and 100hp for handling the big 4x4x8 bales of hay they use around here. Go to Frey’s web site and check out the video it is crazy. If you want I can post pics when we get it installed.
Buck
/ FEL's #16
I just picked up an F16D and would love to see your setup. I was looking at a Koyker, but I am a bit worried about the distance in front of the front axle.
/ FEL's #17
Also, which model Koyker did you go with? They are quoting the 120 for me, but now I'm thinking about going smaller to keep it as close as possible to the front axle.
/ FEL's #18
I don't have any pictures of it right now, jimmer. I've been having fun working the tractor.:D Good tough tractor. Do anything you want it to. I went with the 120 Koyker. The smaller model would probably have suited it more. But the 120 works great for what I want it for. With a some ballast behind ya. Welcome to TBN!! Great place to hang out. Ask about anything you want, somebody will give you an answer. :p Your welcome to come down here in the southern Ozark Hills and look at it. :p John47 lives just down the road from me.
/ FEL's #19
Glad you've been having fun - that is what they are for :)
TBN looks great! I used to have a 155d for a bunch of years We had the wheels stepped all the way out. What a crawler. That think was bullet-proof also. But, the person who bought my dad's hunting camp required it as part of the deal.
Thank you for the offer to come down & look, but a Maryland to Missouri drive isn't something I really have time to do at this point :)
Is there anything I need to look out for on this F16 besides the normal oil change, etc?
Thank you for the quick reply. Now, I have to dump & run. Heading out today for a 2 week vacation! Won't be online for 2 weeks, but I'll check back in when I get back.
/ FEL's #20
Vacation time, must be nice. Well enjoy. As to anything to look out for. Mine is pretty much bullet proof, also. Some parts can be hard to find. And expensive as they have to come from Japan. One of the dealers that post here can find what you need. One thing to watch is the radiator screen. It is in front of the radiator. Gets clogged easily when bushhogging. Check it often. Pulls out, so easily cleaned. Simple to work on if you have any mechanical knowledge.
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2008 DOOSAN G25 GENERATOR (A60736)
2008 DOOSAN G25...
2023 Global Trailers GT302 30ft. 60YD T/A End Dump Trailer (A61568)
2023 Global...
2006 Link Belt HTC-8675 75 Ton Hydraulic Truck Crane (A60352)
2006 Link Belt...
Snap-On Southern Thunder Edition 24-drawer tool box (A61307)
Snap-On Southern...
