FELs and digging
/ FELs and digging #71
The good thing about this thread is to see the OP ask a question, get a variety of perspectives and then the OP come back and tell us about their actual experience, ie, what worked and what didn't.
/ FELs and digging #72
Oh, I would expect it to alter the outcome a very great deal! I would absolutely have preferred a heavier machine. I mean, I'm a normal tractor admirer, bigger is better. But, then, tuppence is tuppence, right? And I'm just small change.
I had a 4 hp riding mower when I was little, the blade removed. One of my friends had a mini-bike. Another had a go-cart. But I loved that thing. With that as my first experience, I'm appreciative that I wound up 50+ years later with what I do have. And I completely believe you about the weight!
bigger is not always better, I have to be careful when i drive on my lawn due to the extra weight around my septic system, underground water lines etc. I have often thought about getting a SCUT for work close to the house. also my carport is too low for me fully pull it into so the @$$ end sticks out in the sun until i build a taller storage building.
/ FELs and digging #73
I have a SCUT not even a CUT and I regularily dig holes 3 or 4 ft deep by 5 ft wide in clay even, with my 2008 BX2660 FEL and tooth bar. But first of all I make sure that it is a fairly wet part of season to do the project, or I take my time to peel layers off the ground and remove . The toothbar is invaluable, and if sod covered ground I bust it up first with the tractors rototiller. Oh and you always need weight of a rear implement or weight box for traction. I also need a small tractor because I drive it over my septic bed to cut lawn with it. Just my SCUT two cents :)
2014 Ford Taurus Sedan (A59231)
2014 Ford Taurus...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2021 Dodge Charger Sedan (A59231)
2021 Dodge Charger...
2017 Nissan Altima Sedan (A59231)
2017 Nissan Altima...
