Loader FEL
TheeKb
Grand Ridge Florida
Mahindra 4025
Any of you ever drilled holes at the bottom of your FEL bucket? I always park it with it facing down so water won't sit but thought about doing it for just in case and for when I'm moving muddy earth around so the water can drain out and I can get more earth than water... can't figure when I would wo t to move fluid?? thoughts?
Drilling a few holes won't let drain fast enough to spit wehn you are moving wet earth. To drain water while parked, that should work fine.
As ArlyA wrote...holes will plug quick.
.. except when you have mud in there while the bucket's raised high and the tractor's moving into a headwind. Then it'll drip into your face.
I wouldn't. I have mixed concrete before in my bucket and have used it to carry water to newly planted trees to far from the hose.
Likewise - I would not drill holes. A bucket full of rainwater will hurt nothing. There will be future jobs where you will be glad you have a "tight" bucket.
Yeah don't think holes will be your friend in the long run. One of those ideas that probably wouldn't pan out unless you had a specific application that required that feature. Don't know what that might be though.
I take my bucket off to give me extra space in the shop, had an old RR tie laying around, I just drop back of bucket on it so it angles down & I don't have to lower arms to far to hook it back up.
Ronnie
If you park it angle down there is no need for holes. Unless you drill a lot of them you won't get any appreciable air flow.
I can already see once the horses are home and new pine trees planted using the bucket to haul water. Got to water trees and fill troughs. Also installing new well so water for horses should be doable w a hose but not for the trees.
I flip mine over with the loader boom and then flip it back when I hook back up.
Ha,ha - carrying water for newly planted trees brings back old memories of the first years we moved here - 1982. We got little trees of all kinds from the local forestry dept and planted them all over the 80 acres. Then we realized that we could NEVER afford enough garden hose to reach them from our irrigation system.
I had a small(1500#) trailer and twice a week we would put four 55 gallon drums on the trailer, fill them with water and spend half a day watering all the trees. My property is too rough, bumpy etc to carry water very far in the bucket. However - many times we would run out of water before all the trees were watered and I would scoop buckets full out of my other lake to finish the job.
JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A64553)
JMR 78in Dual...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
Woods XC48 3Pt Mower (A66408)
Woods XC48 3Pt...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
