FEL valvle problems dongfeng ZB25
   / FEL valvle problems dongfeng ZB25 #11
There could be two P ports, and two tank ports for best mounting situations.
Can you confirm that the fitting with the 90 degree hose is a PB fitting.
Just remove the fitting and it should have two o-rings on it. Take a picture of the fitting removed from the valve. If it looks like the fitting I posted, then it is a PB adapter.
PB is a high pressure path for the fluid to progress to the next valve, and used in most situations because there is usually another valve downstream.
T ports usually go to a tank line and can be teed.
Your flow path might be something like this.
Pump to three spool valve, to remotes if you have them, and 3pt.
I can confirm the 90 fitting does not have 2 O rings. It is exactly the same as the tank fitting but with a 90 deg angle. All ports have one O ring that slot into valve side of the ports (acts more like a washer). There is only a size difference with the tank/pump ports compared to the work ports. As far as I can figure, the valve is standard on an 'East Wind' tractor (DongFeng factory). Dong Feng tractors are a poor mans poor mans tractor so probably get downgraded a bit on parts since the original valve was simpler. Apparently Dong Feng means 'east wind' anyway.
Big Tex T/A Flatbed Trailer (A56858)
Big Tex T/A...
2019 Case IH 370 Steiger (A57148)
2019 Case IH 370...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2267 (A58376)
2267 (A58376)
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
