FEL valvle problems dongfeng ZB25
   / FEL valvle problems dongfeng ZB25 #11
There could be two P ports, and two tank ports for best mounting situations.
Can you confirm that the fitting with the 90 degree hose is a PB fitting.
Just remove the fitting and it should have two o-rings on it. Take a picture of the fitting removed from the valve. If it looks like the fitting I posted, then it is a PB adapter.
PB is a high pressure path for the fluid to progress to the next valve, and used in most situations because there is usually another valve downstream.
T ports usually go to a tank line and can be teed.
Your flow path might be something like this.
Pump to three spool valve, to remotes if you have them, and 3pt.
I can confirm the 90 fitting does not have 2 O rings. It is exactly the same as the tank fitting but with a 90 deg angle. All ports have one O ring that slot into valve side of the ports (acts more like a washer). There is only a size difference with the tank/pump ports compared to the work ports. As far as I can figure, the valve is standard on an 'East Wind' tractor (DongFeng factory). Dong Feng tractors are a poor mans poor mans tractor so probably get downgraded a bit on parts since the original valve was simpler. Apparently Dong Feng means 'east wind' anyway.
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
Water Pump (A57454)
Water Pump (A57454)
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2010 BMW 328i (A56859)
TANK MANIFOLD (A55745)
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
