FEL uses
/ FEL uses #11
Hambone rather than use the forum bandwidth I went out took some pics and threw a montage together on my space at Eagles' Nest
I do need to add that the grass is not back in yet and all the plantings around the pond are just getting started. I spend more time getting the eco-system going in the water than around it for now. Over time I should ge tall the other landscaping around straight again.
/ FEL uses
wow hambone,
very nice indeed. that's a beautiful property
/ FEL uses #14
Farmerpsv, That is eagle's property. I wished mine was that nice!
You did a good job Eagle! You did all that with the BX2200?
I live in flat old farm ground, I think I will start one this weekend. It is clay based soil too. 12x20 is just the size I was thinking. It will get some runoff from the field. The gutters and field tile all tie in right where I was wanting to put it, so should be able to stay full. I have another tile going to county road I can raise for overflow.
About a week eh? Did you use mostly BB to move everything?
Sorry about long post. Getting excited. I have been wondering if I could do that or not. Or how long it would take.
/ FEL uses #15
Now I wish I would have taken some construction pics but.... never did. Anyway I did all the digging and dirt removal with FEL (without toothbar, I'm sure one would have helped). The pond went in a low spot in my yard where the culvert from across the street drains. It had an existing ditch but it always flooded the entire area when it rained hard at all. I happend to catch the ground the one week this year when it did not rain, so it was soft but not muddy on the top. I could dig about a 1 foot or 2 before it would mud up real bad. Then it would dry down enough the next day to allow another foot or so the next evening. You don't know how I glad I was it did not rain... Then I used the removed dirt to raise the grade around the pond. I did use the box blade to drag a 4 ditch for the overflow and help spread the dirt around the pond. The night after I had it all dug we got a huge T-Storm and it's be full ever since. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
I just worked my way from the long in slope that I could backup with load. I tried the box blade but the Turf tires could not get the traction on the moist clay to pull it effectively. Once I was down about 3+ on the far I came in from the side/ends and worked another slope down. Then just backdragged around the edges to make it bit steeper near the top. I also added some "sod" (lumps of grass scooped with the FEL) around the edges to raise it bit more. Now I'm building up the surrounding area up to level the edges and letting the grass come in. Lot's of bermuda around here so it spreads fast.
I did learn that the run off I receive is a LOT more than I thought, during a good storm it will flow over a 10" deep creek over my 4 foot wide spillway. That was reason for raising edges a bit more. The first time it really rained the pond overflowed in all direction including some I did not want. I think I have pretty much under control now. We do loose a fish or 2 now and then over spillway but the Goldfish and most of the other seem to find a quiet spot during rain and stay put, and we have had enough rain this summer to test this almost daily.
It was/is a fun project just take your time and be careful... I got it a bit tippy and "mostly" stuck in the hole several times. It ammazed me how quick the tractor would dig a wheel into a soft spot once loaded and lift the rears. Taught me real quick to slow down and watch where the wheels where going. I'm still playing with the overall layout but as long as you can to the edges you can always dig or drag the dirt around to tweak things into shape unless you wind up having to install a liner. SO far it's staying pretty full. I loose about 4-8" in week but after that it seems to slow down. I'll see how it really does when we get a dry spell.
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2006 Takeuchi TL150 Compact Track Loader Skid Steer (A59228)
2006 Takeuchi...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
