FEL trick
/ FEL trick #21
Or get a cheaper cam that will record the pic in less resolution/w3tcompact/icons/laugh.gif. I use a lot of different software to resize the pics I take if needed.
/ FEL trick
Re: Examples
awright osarker,
This is on a floppy I had close. It's a fireplace screen I made couple three years ago. Customer wanted a custom screen for his custom fireplace in his new custom house.
I suggested he bring me a pattern.
He did.
I started off with a piece of three eighths plate four feet by eight feet and his pattern made of three eighths plywood.
I made one trip up and that was to install it.
All I had to do was do a test fit. Mark where to weld some tabs to attach it to the rocks. Go out weld the tabs on. Come back in and put it in place. Drill the holes and put in the anchors, pick up the check and leave with a customer for life.
/ FEL trick
Re: Examples
I want to talk to that fool that says an old dog can't learn new tricks!!!!!!!
/ FEL trick #25
I saved this drawtite hitch from salvage and just had to do minor "adjusting"
I tried a boom pole idea, but it bent just outside the receiver.
Can you elaborate on your ideas of support from the bucket bottom?
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
