FEL Tree Trimmer
/ FEL Tree Trimmer #21
but I don't intend on spending days or weeks using a string trimmer or pole saw. I want something that will cut 3 or 4 inch limbs an do it as fast as possible. I also prefer to build it myself. I am a machinist with a complete machine shop at my disposal.
If you were anywhere near satisfied by the cut speed of that guy with the single blade (in the video), walking with a carbide string trimmer would cut at least 5x faster. I think one blade is not worth the effort at all. At least three 12 inch blades so you're cutting a swath almost 3 feet where you can curl the bucket and cut a 8 foot swath,,,,,, now you're talkin. But I still think the lack of other angles will be a hassle and slow you down. Agreed it would be fun to build and worthy of horsepower.
But if all that's happening now is you're getting hassled while bushhogging, a carbide string trimmer will be much faster and you can cut the stuff farther back wherever necessary. Understood the word "string trimmer" sounds tame, but you're probably forgetting the amount of work a skilsaw can do and how quick it cuts.
Anyway I fully understand the desire to make something like that rig they cut the powerline swaths with.
/ FEL Tree Trimmer #22
Maybe a Pressure washer attachment to a bucket boom could cut through those pesky limbs.
This one is cutting a 12"+ log. Add some defoliant to the liquid and you'll eradicate the heck out of the area and leave a barren wasteland for quite some time.:eek:
/ FEL Tree Trimmer #23
Must be a normal pressure washer, I think my 3300 psi one would nearly do that - as long as it took and as messy as it was, I'd opt for the axe over that... Steve
/ FEL Tree Trimmer #24
No way 3300 psi would do that in less than an hour - probably more like a day. Youre talking 10Kpsi and pretty hi delivery. LOTS of power.
/ FEL Tree Trimmer #25
I kinda think that was some kinda evergreen..was falling about to easy
/ FEL Tree Trimmer #27
Given the miles and miles of roads that must be kept open, you would think,,,,,,,, that if driving down a road with blades spinning, would work,,,,, that it would appear more in Google images and YouTube. Maybe everyone's seen the county road dept's flail mowers on articulated arm (on a backhoe or excavator). Search google images for "road side brush cutter" and "fence line mower". Some examples, but nothing like that helicopter scythe.
Anyway I think about this a bit,,,,, because I maintain ATV trails, and snowmobile trails, snowboard runs. In my case I don't want shredded bushes next to the road or trail, because over the years it becomes a mass of ugliness that requires more "work" to get rid of. But because it's flailed, shredded, it can be "soft, sort of "safe". But it looks over the top sloppy and ugly! - why would a guy even bother mowing below such ugly brush maintenance? Certainly that works for some applications though, if you just got to keep the road clear, and not for enjoyment.
I'd think indiscriminate straight line cutting would leave a dangerous situation with sharp sticks, that if you didn't walk the line, inspect, and remove, may even be a liability if not dangerous for your own bush-hogging. I certainly would not leave sharp sticks in the bushes for snowboarders or other recreationists to discover if they went off-trail.
Anyway this is an interesting subject for me.
/ FEL Tree Trimmer
This is private property and it is not in my yard, around my house, or my shop. Don't give a F$%&* about the "mass of ugliness". Just cut it again next year. Certainly no snowboarders or recreationists. Again this is posted private property. And to repeat I am not trimming trees around my house. I does not have to be pretty. Does not have to be spinning blades either. Just trying to come up with something that will do the job and not cost $$$$$$$$.
This last picture is a perfect example of what I am dealing with. Notice the mess hanging out into the clearing just in front of the tractor. It is almost a perfect solution too except I don't think it will go as high as I would like and also for the cost involved.
/ FEL Tree Trimmer #29
I bought one of the ditcher flails mower this year, not as good as picture by the manufactors does ok on the ground but once in the air to cut the side of you'r trail's leaves a scragly mess. no way it will take on the larger stuff you wish to cut anyway best just pick days with nouthing better to do and go after it with poe saw @ wheed eater with saw blade. Slagiatt
/ FEL Tree Trimmer #30
... that or get a giraffe.
The idea of being unable to get out of the way in a tractor seat while limbs are dropping from overhead doesn't seem like an ideal arrangement to me unless I had a forestry cab on the tractor. Even then, tree limbs don't always present themselves at right angles to the road, making any kind of cutting from a vehicle kind of sub-optimum right from the start. I'd get a good quality pole saw and accept that it's going to take some time to do the job right, the first time and then plan to spend a little time on a regular basis to maintain it.
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2015 John Deere 6105E (A60462)
2015 John Deere...
2018 FORREST RIVER WILDCAT BUMPER PULL (A60736)
2018 FORREST RIVER...
John Deere 6300 (A60462)
John Deere 6300...
