Front-End Loader fel tooth bar
/ fel tooth bar #1
seedman4
i want to build a tooth bar for my fel.were is the cheapest place to but them?bucket is 60 inches wide.how many teeth do i need and how far do i space them.i have 3/8x4inch and 3/8x6 inch plate which is better to uswe for the teeth bracket??
/ fel tooth bar #2
Oddly enough, there is a person on ebay that sells several types of shank and tooth. His prices are very reasonable. Search for "bucket teeth" in the business and industrial area.
3/8 x4 is probably all you will need.
jb
/ fel tooth bar #3
This place was the least expensive I found Terra-Cut Rubber Tracks and Replacement Wear Parts
$144 shipped to my door for 8 Fabco adapters and crimp on teeth. Should be less $$$ for you since they were drop shipped (not cheap) from Ohio. Seems like most people are using 7 teeth on a 60" bucket, w/my soil (clay)... Glad I used 8. Depends on the thickness of your cutting edge as to what flat stock to use. I ended up with 1/4" x 4". I also made the mount so I can just pull the tooth bar forward and flip it up to the top of the bucket without actually removing it to get it out of the way.
Let me know if if you go this route and need Fabco part #'s
/ fel tooth bar #4
I used a guy on ebay. Just looked him up not much there right now! But he was way cheaper than what I could get them for locally. I bought shanks and teeth. Wish I would have gotten the pins from him too. He had them for 2.25 I paid 3.75. I used 4"X.5" and welded the shanks on. I still warped the flat, but I'm not a welder either.... It still works great though. Hope this helps.
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
1988 CAT 815B (A68134)
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
SERVICE BED FOR TRUCK (A67714)
SERVICE BED FOR...
