`FEL stays in float
/ `FEL stays in float #1
dbelisle
New Hampshire
Mahindra 2810HST
A friend of mine has a 4200 with a FEL that does't have any down pressure.
Any ideas what it might be??
/ `FEL stays in float #2
Just a guess, but sounds like the hydraulic line for that function is not hooked up properly or is plugged for some reason. That would be the line that goes to the boom cylinders on the end that collapses the cylinder. Disconnect it at the valve and reconnect it to make sure it seats good and try again. And if that doesn't work, then I don't have any good ideas. /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
/ `FEL stays in float #4
And check to be sure the system is full of fluid and there is nothing interfering with the lever when pushed forward.
Bird, no bearing on the matter, but it sure is easy to see where you made a post, with that colorful outfit. /forums/images/graemlins/smile.gif
/ `FEL stays in float #5
It looks like he is ready for the deer woods...... /forums/images/graemlins/grin.gif
/ `FEL stays in float #6
dbelisle,
Did it used to but now doesn't? Is he sure he's not putting it in to float by pushing the lever to far forward?
Mine is not a 4200, but I was having dump and float problem (not able to do either but all other functions worked) and found the bottom mounting bolt for the SCV loose. Tightened it and all is well now.
Just some ideas.
2019 KENWORTH T370 FLATBED TRUCK (A65643)
2019 KENWORTH T370...
2022 EZ-GO ELITE...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
(8) Used John Deere Hydraulic Cylinders (A65640)
(8) Used John...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
