Snow FEL shoes
/ FEL shoes #1
Mac25
Danville, IN
Kubota B2320 HST with LA 364 FEL
Anybody ever fabricated a set of FEL shoes for snow removal on a gravel driveway?
/ FEL shoes
Just with the bucket. Want to fabricate something that will bolt to the bucket so that I dont have to drill any holes in the bucket.
/ FEL shoes #4
Curl your bucket up a little past level . This will keep it from digging in , till things freeze up a little.
/ FEL shoes #5
I've heard of buying the shoes that are meant for truck plows and adapting them to either a front/bucket/blade or rear blade. How you would do that without welding or bolting (drilling a hole) is beyond me.
/ FEL shoes #6
I've done just what you were talking about, they are skids more than shoes.. they work very well, with the ramps on the front of the skids you can curl the bucket down a little to scrape as low as you want to go without getting gravel. I had to add some weld to the front of the ramps after the first season as they were starting to wear thin. Since then they haven't worn much, I guess the weld was better material.
Like Oldballs was saying, I had to drill 4 holes through the bucket on each side to attach them, then file the holes square to accept carriage bolts. The holes haven't caused me any problems in the off season.
The body is built from 1/4 plate, except for the crossbar on the back which is 3/8 I think. They bolt up through the reinforced section of the bucket so there's no worry about them tearing out. Let me know if you want more detailed pics.
The screen for the bucket makes a big difference for snow clearing, you can get almost twice as much with no spillage over the top. Lights still shine through the screen.
Sean
/ FEL shoes
Was thinking about welding some type of bracket to accept the skid shoes and then using a "setscrew" method to attach to the bucket like they make for pallet forks. That way I dont have to drill the bucket.
/ FEL shoes #8
You may find that the setscrews don't hold the skids that well, they take quite a beating compared to forks. I don't know for sure, I didn't try it that way myself.
Sean
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Small Cow (A64557)
Small Cow (A64557)
TAYLOR LASTOVER HARVESTER (A64278)
TAYLOR LASTOVER...
LOOK! (A63111)
LOOK! (A63111)
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
