FEL Rake
/ FEL Rake #1
Bogi
N.E. Wisconsin
Massey 1533
Started my own version of a rake. I will be using chain and binders to hold it on (because I already have them) and have the same tooth pattern top and bottom. Material is 1/2 inch plate cut with a cnc plasma. First post with pic so be gentle.
/ FEL Rake
Yep. The student version of ACAD is free and works great. After making a DWG the Pro-Nest software turns it into a CNC file and you cut.
I'm confident that 1/2 will be good. A few of my other projects were lighter material so I learned when stuff bends and when the tires spin or the rear picks up. I try to take it easy the bucket itself is 7 ga. with 1/2 cutting edge, I'll wreck the rake first.
/ FEL Rake #6
So what material did you choose? That has a lot to do with performance/fail issues.
/ FEL Rake
Its all made of 1/2" Here is a pic of the test fit. Again I would rather wreck the rake than the bucket itself.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
17601CFL (A59228)
17601CFL (A59228)
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
iDrive TDS-2010H...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
