FEL Rake
/ FEL Rake #1
Bogi
Member
N.E. Wisconsin
Massey 1533
Started my own version of a rake. I will be using chain and binders to hold it on (because I already have them) and have the same tooth pattern top and bottom. Material is 1/2 inch plate cut with a cnc plasma. First post with pic so be gentle.
/ FEL Rake
Yep. The student version of ACAD is free and works great. After making a DWG the Pro-Nest software turns it into a CNC file and you cut.
I'm confident that 1/2 will be good. A few of my other projects were lighter material so I learned when stuff bends and when the tires spin or the rear picks up. I try to take it easy the bucket itself is 7 ga. with 1/2 cutting edge, I'll wreck the rake first.
/ FEL Rake #6
So what material did you choose? That has a lot to do with performance/fail issues.
/ FEL Rake
Its all made of 1/2" Here is a pic of the test fit. Again I would rather wreck the rake than the bucket itself.
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A61165)
INOP/NON-RUNNING...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
