FEL quick disconnect
/ FEL quick disconnect #11
Thanks. This did get me thinking. Has anyone caused any damage to their tractor by clearing saplings? I imagine one could puncture a filter, tire, or break a line.
I'm not familiar with the steering linkage on a Kioti, but we have cleared a LOT of saplings with our Kubotas and all we damaged was tie rod boots as the tie rods are in front of the axle. We keep the buckets low which keeps the saplings mostly away from the tractor.
/ FEL quick disconnect #12
Whenever I hear "sapling" I think "punji stick".
It's why I don't sharpen my hog's blades too a point.
Have a hole in my front grill where a sheared off sapling tried to spear my radiator, but was blocked by my battery.
/ FEL quick disconnect #13
I would'nt worry about it to much, You don't have much of a choice do you? I have a 8 or 9 acre field that I knock down once a year, it's amazing how fast the **** grows up. If you keep knocking it down annually those saplings will be history. Good luck.
I just looked under my tractor and I notice one of the wiring harness snapped off. I was able to snap it back on the plactic holder. There seems to be alot of small things, such as wiring that can get damaged from saplings.
The past 4 years we have be renting a tractor to bush hog the property and I have let a few of my fields go wild. I have just finished 20 acres of saplings and now that I have my own tractor I don't plan on letting it grow 5'-7' as it did this year. Hopefully knocking it down twice or three times a year will kill them off for good.
/ FEL quick disconnect #15
Maybe you should keep your FEL low while mowing, it will bend them over alittle before you mow. Then again if you keep it too low you may hit rocks. I know a guy that was doing just that and he hit a rock and broke 2 ribs from hitting the steering wheel.
/ FEL quick disconnect #16
Maybe you should keep your FEL low while mowing, it will bend them over alittle before you mow. Then again if you keep it too low you may hit rocks. I know a guy that was doing just that and he hit a rock and broke 2 ribs from hitting the steering wheel.[/QUOTE]
That is one of the reasons for wearing seat belt, so you don't slide forward in sudden stop.
When you have saplings bent over driving forward don't back up or they can spring up and go through fan, tear off lines or wires, catch on hydraulic filters, all kinds of not so good things can happen.
The tie rods have metal protector in front of them. Check those after day of mowing to make sure you didn't bend ot tear one off.
/ FEL quick disconnect #17
The Kioti's are pretty well protected there with guards, but there a lot of wiring harness's tucked up under the tractor, It is not like they are hanging down or anything but it is possible that something could get caught on them. Some guys have considered making "belly pans" for the Kioti's.
James K0UA
/ FEL quick disconnect #18
The most vulnerable bits under the tractor are the FEL lines. I have also managed to snag and bend my oil dipstick tube and one time snagged the throttle cable (which was exciting as the engine suddenly rev'd up). I have also had brush "disconnect" the 4wd circuit wires under the left side operator station. The other likely victims of encounters with brush (from personal experience) include the front axle protective shields and the lynch pins holding the 3PT arms. I have a couple dents in my grill despite a factory grill guard too. Of course there are also the HST and hydraulic filters underneath the tractor which have dents in them but no real damage on mine.
Mother Nature doesn't like it when you mess with her babies so be careful when you engage in toe to toe combat with brush.
/ FEL quick disconnect #19
Before going at it with a hammer, I would try to clean them out. I have had dirt in the female connector prevent connection.
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 HINO SA (A58214)
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
MASSAGE CHAIR (A58214)
