FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #21
I too have both, and used both.
A loader plow is WAY too far forward. That in combination while the plow is down you have very little weight on the front tires.
Add it up and you have a ~20' lever from plow to rear axle that when the blade is angled.....you will fight constantly trying to windrow any measurable snow as it will just keep pushing you sideways.
Yes it even happens with a rear blade, and its much closer to the rear axle. So it takes alot more force to make that happen.
But given the size and light weight of your machine, I'd stick to a rear blade and leave the loader bucket on for use when needed
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #22
I like using both. The trouble with a quick attach plow is it is difficult to keep it from digging in and pushing up the front of the tractor. Using loader float does not help. I added float to the curl function which helps some but you still can't scrape the drive clean. Mostly I just set the FEL to plow several inches above the drive and use the back blade to clean that up. I use them both at the same time.
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #23
I guess everyone's situation is different. My ssqa plow does fine for my conditions and terrain. I don't float the fel, I just barely set the plow down and leave the fel weight on the front tires. Feather as needed.
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #24
Front mounted plow works extremely well with several caveats:
1) You still need Left/Right brakes to correct steer/heading angle in the event that the plow finds a load condition that make the tractor veer to the side when the plow is at high angle.
2) You need a plow WIDE enough so that when it is at high angle (needed when there is a lot of snow depth), you can cover the width of the roadway lane you want to clear. Otherwise you have to make another pass to widen the cleared lanes.
3) You need a curl function on the loader arm mounted plow because there tends to be an optimum side view angle to keep the blade down depending on depth and 'weight' of the snow ('fluffy' or 'wet'). (so third function).
4) You need a rubber scraper blade wiper to follow the road surface because there will otherwise be gaps in the plowed lane which will trap water snow & ice, make the road possibly MORE dangerous than leaving it unplowed. [Insert legal implication problems here].
5) You need to keep the tractor going as fast as possible, so that the Karens following you don't blow their horns and flash their headlights because you are in their way on a trip to have their Saturday morning toenail refinishing appointments. If they try to pass you, there may be a collision, or worse, you might feel inclined to stop and help pull them out of the ditch they wind up in. You may feel guilty about needing $50 from them to pull them out, they may not have the cash, and now they have to walk back home in the cold with just thongs on their ugly fake tanned feet. {Been there, suffered from that, needed counseling to accept their fate].
6) To get the best traction AND steering, lots of rear weights works best if you have the brake steer option.
7) Either way the plow is mounted, you should have float as an option for obvious reasons.
8) The front mount plow (not using the loader) works best in your own yard & driveway because it doesn't take up so much space needed for tight maneuvering. Plus you can get substantial downforce on the blade for those pesky tire tracks frozen to the road from previous traffic.
9) Get a good rear view mirror to see how many vehicles you a blocking as you plow. When it gets to 3, pull over and let them get stuck ahead in the unplowed road. Then plow snow right next to them to block them in. When it freezes like this, a tow truck's extra fee to yank them out will remind them of a Patience & Courtesy meme.
I used to do our whole 1.4 mile road with this tractor running in high gear. The extra weights add to the momentum needed to move a lot of snow out of the way. But since retiring, I now make some cash from the $50 towing fee and get the satisfaction of assessing the character of new neighbors.
Thanks for all of the great responses.
My takeaway here is that both the front flow and rear blade are workable options. Since I'm only going to use this a couple times a year and some years not at all, I'm probably going to go the rear blade route, as that also gives me more of a multi-purpose tool as well.
For the folks mentioning snow blowers, I have the gear drive version of the L2501 and the reverse gear selection isn't very good. And with the little horsepower I have, I'm not even sure that the first reverse gear would be low enough. I also don't think I get enough snow to really justify a blower.
For the folks mentioning pavement marking and such, I'm mostly just trying to not upset the neighbors. We all pitch in and paid for the chip sealing recently, and while most will be thrilled to have the snow removed, I could see a few folks not being happy about my scraping it up. So if I have to spend a few bucks to avoid that, it's money well spent.
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #26
Thoughts? Similar experience? Any input is appreciated.
When you ask for opinions, that's what you get . . .
I don't think there's any better setup than a plow out front and a snowblower on the back for stuff you can't handle with the plow. You don't see the county or state trying to plow snow by dragging a blade behind them. I don't like packing the snow by driving over it first and we get drifts along fences and in low spots that you can't really just drive through. A plow out front lets you keep your tires on plowed ground. A plow will do a better job at rolling the snow and pushing through a heavy snow that you'd bog down in with a rear blade.
A cheap Meyer plow, or similar, is easy to adapt to a SSQ plate and can be found pretty easily, at least around here. There are lots of old plow blades, A-frame with cylinders around. If you have rear remotes, you don't need the pump or truck frame or light bar, etc.
A mile is a lot to clear if there's very much snow. My only reservation with this free advice is that I think you might want to start looking for a cab tractor. If you're going to put together a package for the long haul, I think you at least need a cab tractor as a foundation and build on that. And a little more weight. It's a life-long investment if you take care of it.
I tried to dig out about the same amount of combined driveways using my 30 HP open station Kubota. Started with a FEL and rear blade. Quickly added a snowblower to handle the drifts -- MUCH faster than shoveling it out with the bucket. Took me a few years to piece it together, but a repurposed Meyer plow on the front of a cab tractor with a snowblower on the back for weight and backup is the ultimate snow machine as far as I'm concerned.
That's my opinion, FWIW. Best of luck on your setup.
Update ---- Just read your last post. You only need this "a couple times per year and sometimes not at all." In that case, disregard the above and just use the front bucket and rear blade that you were complaining about!
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #27
For $150 I found an old Ford very light duty 7' rear blade to use on our chip and seal county road because the backhoe was a over kill.
Living on the Mississippi River end of Kentucky for the last 10 years I haven't hitched to it because the warmer winters that brought the armadillos means by 2pm the road most often is drivable with no plowing.
In 2014 I got the FWD Ford Taurus that did well in our typical snows. In 2018.we got the 2010 Subaru Forester so why freeze my old butt on the old tractor. Got the 2023 Tesla Model Y dual motor long range this past January and it's the best ice/snow mobile I have ever owned. On wet ice I can take off going WOT and never spin a wheel. The all wheel Regen braking is a plus.
At 22 plowing snow on a open tractor was cool but totally not at 72.
Be careful this coming winter. Some are calling for a ton of ice and snow.
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #28
With 24hp and a 2500lb machine useing any type of blade with a 12in wet storm your going to need to plow about every 5in.
Is this a shared driveway? If so find out how the other owners want to handle snow removal because it's really not all your issue.
They are on board and happy to help out with the cost. And I'm at the end of the road, so road things seem to be more of my problem if I want to get from one end to the other :)
   / FEL plow vs. rear blade for 1 mile of infrequent chipseal road snow removal #30
I plow with a 6' backblade with a 24HP tractor that is liighter than yours. Our snow falls are typically 3" to 6 ". Some years up to 12" per snow fall. I have no problem with moving snow with the backblade, other than what @oosik mensions above about healing time.
My backblade has horse stall mat attached to the bottom of it and I plow at 6 to 7 mph.
When the snow is wet I use "edge tamers" on my front bucket to clear the snow if the snow buildup on the backblade gets to heavy. This is a slower process.
I plow 3 driveways for a total distance of 3700 feet.
With your 2501 I don't think you will have any problems plowing a mile with a 7' backblade. Just find a heavy duty one for the weight.
Your mileage may very, depending on conditions where you live.
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2020 CATERPILLAR 120 MOTOR GRADER (A51246)
2020 CATERPILLAR...
2012 Ford F-150 Pickup Truck, VIN # 1FTMF1CMXCFB58514 (A51572)
2012 Ford F-150...
2016 Mobility Ventures MV-1 VAN (A51694)
2016 Mobility...
