FEL PIN
/ FEL PIN #1
glc24
Platinum Member
Southwestern, Pa.
Hi guys
Is the level indicator supposed to be tight against the bucket mount or loose?
I was cleaning debris around the linkage and noticed I could wiggle it back and forth a little. The nut looked loose,but it is tight to turn with a wrench.
Greg
/ FEL PIN #2
It's fine, it needs to pivot. But it looks dry-grease that thing!
BTW, you can cut that O-ring off the cylinder-it's function was to keep paint off of the wiper seal at the factory.
/ FEL PIN #4
BTW, you can cut that O-ring off the cylinder-it's function was to keep paint off off the wiper seal at the factory.[/QUOTE]
Thank you for this 'Tid-Bit' of info, I have ask most everyone that has looked at my 4520 what it was for and thus far no one has known......Thought that it might have come out of the cylinder, one less thing to worry about.
Jim
/ FEL PIN
Thanks for the headsup guys but I DID see that in my owners manual:)
Greg
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
Two (2) John Deere 5000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
4" Makita Disc Grinder (A62613)
4" Makita Disc...
Ammann AV33E Roller (A65579)
Ammann AV33E...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
Cattle Feeder (A65640)
