FEL mouted PLOW
/ FEL mouted PLOW #11
Now that you mention it, they DO look like Nelson Studs. Nice job...........chim
/ FEL mouted PLOW
Is that what they are? Nelson studs? They were sitting on the counter at the steel place. I said -ooh what the heck are these? I NEED THESE! $1.00 apiece but I think he just threw them in. When I go hydraulic I will install a bearing or something more precise.
/ FEL mouted PLOW #13
Just a suggestion, the tubing size you have for the A frame pivot looks like it is a bit undersized. You may want to go with something bigger like 3 or 4 inch box to give you more strength. This is the highest stress area as all loads are concentrated at this point and it will be the first to bend/break. If you look at the A frame for a truck plow you will see how large and beefy this part is on the plow. Nice work!
/ FEL mouted PLOW
Thank for the advice. That was my opinion too - as you could see, I ignored it. I'll test run it tomorrow.
/ FEL mouted PLOW #15
I sure hope you post a pic or two of your process of holding the 1/8" steel in place for tacking. Sounds clever.
/ FEL mouted PLOW #16
Just a suggestion. At your pivot point and index pin locations, if you drill them oversized and weld in a pipe bushing sized to the pins, you will get less wear and egging of the holes in the tubing. It won't fully make up for the smallish size of the tubing in those locations, but it will help a lot. Of course, if you've already done that I have just insulted you. /forums/images/graemlins/blush.gif Actually, I'm impressed with your progress thus far. Congratulations!!
/ FEL mouted PLOW
Welder? What welder? I used hot glue /forums/images/graemlins/cool.gif
I use a Millermatic 210 MIG and a Spectrum 375 Cutmate plasma cutter.
/ FEL mouted PLOW #19
How do you like that welder? I'm considering a 251 to replace my little 110v miggy.
/ FEL mouted PLOW
<font color="red"> Spectrum 375 Cutmate plasma cutter
</font> My mistake. I have the 625 Cutmate.
I love the welder. It came with a free spool gun as well. You could switch from one to the other with no hassle at all.
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
John Deere 5100M (A53317)
John Deere 5100M...
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
