FEL Model 70 line replacement
/ FEL Model 70 line replacement #1
bama7
Middleburg, Florida
John Deere 855
I finally traveled to get the JD Model 70 Loader I purchased around March. I was in hopes the lines and hoses would be in useable condition. Dream on. I checked prices for replacement hoses and lines and they are not reasonbable at all for a frugal person like me, cheap. My thought is to replace everytrhing with locally manufactured hoses. I don't want to use any metal lines if I can get away with it. First off would it work? I don't know of any reason why not. And secondly has anyone on here done that before? I would think someone has. Thanks
/ FEL Model 70 line replacement #2
Yep, ask around what the best local spot for hoses is.
Check the lines over carefully, only replace what is bad for certain. Get it up and going to check the ones that are suspect.
/ FEL Model 70 line replacement #3
I see you list that you have a JD855.... ??
When I had an 855 with a 54 loader, I could take the hose to my local auto, farm store and they would make a new hose with the old hose ends..
Sadly there isn't enough hose to measure for length or any fittings worth saving. Mine would be a complete replaement. One thing I need to do prior to spending money on new hoses and stuff is to attach it to my tractor to verify fit. I have read some posts about the 70 loader not fitting the 855 tractor. Others say it will.
I am in hopes it will fit. Just got to get my sons to come over to put it in place.
I emailed Koyker to see what they had for my 855. And they said their Model 155 was the one for the 855. I got with our JD dealer to call for a price quote. It would be close to $6,000 after the install by JD. JD install would be anywhere from $200 to $500 depending on how the kit fit and if my tractor fittings and hoses were good. I got a quote from Westendorf for their Model TA 55 and it was $4,818, which included the shipping to north east Florida. If the Model 70 I have will fit my tractor I think I will take it to my JD dealer to have them give an estimate to do the entire job. I would rather have original equipment if the price is right.
/ FEL Model 70 line replacement #8
Based on experience, the hoses fabricated by my local hydraulic shop are far superior to the ones I got new oem from Koyker with my loader. The locally manufactured hoses seem to be thicker material.
/ FEL Model 70 line replacement #9
My local NAPA store repairs/produces replacement hydraulic hoses that are thicker. One day service. One hour service on slow days.
Not sure how NAPA would match their selection of hose end connections to your tractor without sample originals. Length is not too critical; be sure to tape measure with Loader at full extension for each hose.
Dream on. I will speculate that Deere mechanic time in Alabama is billed at around $100 per hour.
My main thought about going to the dealer was in hopes they may have all the specs for making the hoses and lines. I will check with NAPA to see what they have to say. I added my location too. I am located in Middleburg, Fl around Jacksonville.
Hydraulic repairs around Jacksonville, Florida:
hydraulic service around jacksonville florida
Thanks for the info!
/ FEL Model 70 line replacement #13
As for fittings, since you plan on doing all new soft lines (no hard lines) your fitting needs are determined by your control valve and you hydraulic cylinders.
I suggest you pull one cylinder, you decide if one is easier than the others. Buy a fitting to fit this cylinder as you take it to a shop with you. Ideally this fitting fits all of your cylinders on both ends. If so you have 1 answer to your fitting needs. Take lots of pictures, make drawings and decide the route your hoses will take. Take careful measurements of these routes allowing space for movements as the cylinders pivot during extension and contraction during their usage.
Note: you will need to split lines for every route that cylinders work in conjunction (2 to 4 lines). Be sure to use fittings rated for the pressures that will be in use on the hydraulics!
The other area for fittings on the loader will be at the control valve. Take it with you when you are ready to order the hoses. There are likely to be 2 sizes of fittings (could be more but 2 is common). 1 size is your supply and return lines, which you need to decide how they will run and connect to your tractor. The other size is those going to your cylinders likely 4 ports ( 2 for loader lift and 2 for bucket functions). While you may have 8 ports on your cylinders (if 2 cylinders for bucket) note above I stated the hoses need to split to go to both cylinders.
/ FEL Model 70 line replacement #14
You are going to be disappointed in how much all the hoses will cost. The metal from the factory was probably installed because it was less expensive.
How bad are your metal lines? Are they missing or damaged?
Another concern on a used loader that old is cylinder condition. I would open those up, check the bore and piston condition, and replace the seals first. if those are not repairable you would want to look into generic cylinders. THAT would alter line location and fitting needs as well as require different hose lengths.
I recommend Gates hose and fittings. My grapple has USA made Parker hoses and the covering is all cracking at less than 3 years old.
Edit: If you want to configure new steel lines these fittings might be your answer.
I think the lines on that loader are going to be 1/4".
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2015 CHEVROLET CAPRICE  CAR (A66091)
2015 CHEVROLET...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
CAT C1.1 LITER WITH GEN END (CONDITION UNKNOWN) (A68842)
CAT C1.1 LITER...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
