fel hydraulics
/ fel hydraulics #1
cranker
QUick question. When using 2 cylinders to operate one device (fel loader) do you need to run a hydraulic divider to equal the lines when split or can you use just a regular tee? Same with the curl cylinders. i would think that if you dont regulate the flow to each one they could possibly apply uneven pressure to the bucket say if the bucket had a load that was lopsided. What type o divider is used in this situation.
Thanks Crank
/ fel hydraulics #2
Most systems just use a tee in the lines.
/ fel hydraulics #3
Thanks Crank
Every FEL I've ever seen just uses a "T", but the bucket is solid enough to take any uneven strain. In a weaker application you may need to worry about it, but on a FEL it will be fine.
/ fel hydraulics
thanks for the quick replies guys. it helps me out a bunch...
/ fel hydraulics #5
As others wrote...just use proper T's and you will be fine. NO cast plumbing fittings from home Cheapot or Lowe's!.
DEERE 410J Engine (A68134)
DEERE 410J Engine...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
16ft. Terry Bass Boss Flats Fishing Boat w/ 18ft. S/A Boat Trailer (A66738)
16ft. Terry Bass...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2004 (INOPERABLE) INTERNATIONAL TRANSTAR 8600 (A67714)
2004 (INOPERABLE)...
