fel hydraulics
/ fel hydraulics #1
cranker
Member
QUick question. When using 2 cylinders to operate one device (fel loader) do you need to run a hydraulic divider to equal the lines when split or can you use just a regular tee? Same with the curl cylinders. i would think that if you dont regulate the flow to each one they could possibly apply uneven pressure to the bucket say if the bucket had a load that was lopsided. What type o divider is used in this situation.
Thanks Crank
/ fel hydraulics #2
Most systems just use a tee in the lines.
/ fel hydraulics #3
Thanks Crank
Every FEL I've ever seen just uses a "T", but the bucket is solid enough to take any uneven strain. In a weaker application you may need to worry about it, but on a FEL it will be fine.
/ fel hydraulics
thanks for the quick replies guys. it helps me out a bunch...
/ fel hydraulics #5
As others wrote...just use proper T's and you will be fine. NO cast plumbing fittings from home Cheapot or Lowe's!.
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
International 37 Square Baler (A65640)
International 37...
26 Gallon Dewalt Air Compressor (A65579)
26 Gallon Dewalt...
