fel hydraulics
/ fel hydraulics #1
cranker
QUick question. When using 2 cylinders to operate one device (fel loader) do you need to run a hydraulic divider to equal the lines when split or can you use just a regular tee? Same with the curl cylinders. i would think that if you dont regulate the flow to each one they could possibly apply uneven pressure to the bucket say if the bucket had a load that was lopsided. What type o divider is used in this situation.
Thanks Crank
/ fel hydraulics #2
Most systems just use a tee in the lines.
/ fel hydraulics #3
Thanks Crank
Every FEL I've ever seen just uses a "T", but the bucket is solid enough to take any uneven strain. In a weaker application you may need to worry about it, but on a FEL it will be fine.
/ fel hydraulics
thanks for the quick replies guys. it helps me out a bunch...
/ fel hydraulics #5
As others wrote...just use proper T's and you will be fine. NO cast plumbing fittings from home Cheapot or Lowe's!.
(4) 275 Gal Chemical Container (A64912)
(4) 275 Gal...
2003 (INOPERABLE) CHEVROLET C7500 (A67714)
2003 (INOPERABLE)...
2011 FORD F-150 (INOPERABLE) (A67714)
2011 FORD F-150...
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
