pharmvet
Platinum Member
- Joined
- Sep 28, 2008
- Messages
- 534
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have a real hankering for a brush grapple for my tractor. Ive been reading all the posts on the subject that I can. Seems that most of the posts about grapples are on small CUT tractors. I have some specific questions regarding a grapple for my tractor (100 hp). Im planning on using it mostly to pile and burn brush and logs etc. I am trying to implement many wildlife habitat improvement projects and seem constantly to be trimming limbs and cutting trails, burning brush, etc. It seems that one of these grapples would be one of the handiest implements I could have.
1) What is the heaviest (actual wt. of grapple) grapple I should consider?
2) What width would you recommend?
3) Would you recommend 2 jaws (each operated by separate cylinder) or 1 large jaw (1 cylinder in the middle)
4) Are there specific brands I should consider?
5) Will I need to have special hydraulic plumbing installed or can I use the rear remote valves to open and close grapple jaws?
thanks in advance
thanks in advance
