Front-End Loader FEL forks for subcompacts
   / FEL forks for subcompacts
Rimshot, I see your point. The bucket setup looks great. Do you have any difficulty with visualizing the tips of the forks for placement while you're sitting in the operator's seat?
   / FEL forks for subcompacts #13
Rimshot, I see your point. The bucket setup looks great. Do you have any difficulty with visualizing the tips of the forks for placement while you're sitting in the operator's seat?[/QUOTE
Hi bx24D,
I suppose if visibility of fork bars is an issue the pin model is the way to go. If I skewer the refrigerator with my new forks I think I shall blame the spotter I shall be certain to employ and watch up close as I move to get into lifting position. There's no way I would trust my steadiness without somebody watching. But I don't think fork tip visibility is going to be a show stopper anyway. The first thing I do if heavy lifting is in order will be to raise an old pallet slightly just short of the pickup truck tail gate premounted on tractor forks. Something like a refrig or washer/ dryer can then be manhandled from the tail gate down to the pallet. That will diminish chances of screwing up........even for a clutz like me.
rimshot
   / FEL forks for subcompacts #14
I finally bought a set of LandPride PF10 clamp on forks for moving mulch bales 5 at a time on a pallet which I attached to the forks, so when the bales arrived at the compost pile I could just dump them and go back and load 5 more onto the pallet...moved over two hundred that way...had to tighten the forks twice...for a simple one-off task they worked well...;)
Land Pride Pallet Forks
   / FEL forks for subcompacts #15
these are the greatest things ever. these and the tooth bar
   / FEL forks for subcompacts #16
This works for me, cost less than $120 and has held 500 lbs. so far.
Is that just channel iron for the forks and frame? Nice setup. I only need lightweight lifting and this looks like something I could build myself.
Do you have additional photos?
Thanks,
Clem
2001 Ford F-350 4x4 10ft Flatbed Truck (A55852)
2001 Ford F-350...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A57024)
PENDING SELLER...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
