FEL forklift
/ FEL forklift #1
metalbender
Sask, Canada
Massey 1742
Got a new attachment project in the works. Need an extra foot or so extra lift on the Massey 1742 fel. Not quite enough height to place pallets in the old barn loft. Old dairy barn, low ceiling, great loft for storage. Picked up a ssqa plate. Will fab up a short hydraulic lift system, like a fork lift onto the plate. Doesn't need to lift much, 5-600 lbs. Has anyone seen or have such an item?
/ FEL forklift #2
I saw such a device or more speciically a loader with an extra section some years ago at a show. It was either HORST, HLA or FREY.
/ FEL forklift #3
I have not seen a forklift on a FEL but have seen 3 point mounted fork lift masts for doing what you are describing
/ FEL forklift #4
/ FEL forklift #5
Buy a second set of forks and weld them 2’ high. Then use a regular set of forks stack the pallets on a wagon deck and switch to the elevated forks.
/ FEL forklift #6
I can put the forks on my JD 640 Carrier on upside down to gain a bit. But yeah, you need to have the pallet somewhere off the ground to start.
/ FEL forklift #7
Yes I have. Probably here on TBN.
You could start with this style: manual hydraulic stacker - Google Search
Or a small 3 point forklift welded to the attachment plate: tractor 3-point forklift attachment - Google Search
Then there is this style: Extra Lift
Pictures from an image search
/ FEL forklift #8
That looks kind of scary and fragile.
Having forks at height can subject them to great stress when you pull up or push down without realizing it. A FEL is not a forklift.
/ FEL forklift #9
safety police may not like it but what about driving the front tires up on a set of heavy duty car ramps. that may not be enough
/ FEL forklift
I'm liking the replies, many thanks. Lots of sittin'nthinkin' time.
/ FEL forklift #11
Fork lift forks on a loader is done a fair amount, but like was said, you have to be VERY careful when using them...
SR
/ FEL forklift
Looking at the three point units, prob be overkill, too heavy.
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
2010 MACK TITAN (A65643)
2010 MACK TITAN...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
