FEL For Case 830
/ FEL For Case 830 #1
hotrod45
Saskatchewan, Canada
Case 830
Gentlemen:
This is my first post and need your advice and help. I am about to build a FEL for ths tractor but have been told that it does not have regular frame. This looks to be true so does anyone have any picture of a 1966 Case 830 that show how the frame for the FEL is attched to the tractor. Iam guessing that a sub-frame is built that attches to the rear end assembly and mid point on the tractor, and from here the vertical posts are mounted that support the loader arms. Any advice will be greatly appreciated.
Thanks
Derek
/ FEL For Case 830
Gentlemen:
Thanks
Derek
/ FEL For Case 830 #3
Welcome!
Can't offer specifics on the 830. I suggest you keep your eyes open and when you spot an old tractor with an FEL, get your camera out and snap some pics. A lot of the old tractors had FELs that attached at the rear over the rear axle.
Ron
/ FEL For Case 830 #4
Welcome!
Ron
/ FEL For Case 830
Thanks for your efforts guys. I have a bit of an idea of what to do now.
Derek
/ FEL For Case 830
Derek
/ FEL For Case 830 #9
hotrod45,
Here is another picture. This is of a Case 990.
Good Luck,
Russ
/ FEL For Case 830 #10
hotrod45,
Good Luck,
Russ
/ FEL For Case 830
Thanks Russ. That is a great picture and gives me a lot of information. I appreciate your help.
Derek
/ FEL For Case 830
Derek
/ FEL For Case 830 #13
Isnt the 830 a totally different tractor than the 990 ? The 830 is of old American heritage, where the 990 was a rebadged David Brown ? I dont have any experience with American Case because the Case name was unknown here untill they took over IHC, which was a very famous name on this side of the pond.
Over here there is just a small cult of DB people, all other folks hate them because of their numerous design flaws.
/ FEL For Case 830 #14
/ FEL For Case 830 #15
The 830 was a USA field tractor available as a row crop or standard "Wheatland" types. 80ish hp. Available with direct drive trans or "Caseomatic" torque convertor trans. Still some around running lift pumps or hay machines. Granddad had a 630,730, and an 830 at different times...
The David Brown is a UK transplant. I've only seen a few around Arkansas...
/ FEL For Case 830 #16
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
2015 International PayStar 5900i 24ft. Flatbed Truck (A64194)
2015 International...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
