FEL float detent
/ FEL float detent #1
Fall Creek
Granbury,(Acton), TX
Kubota L3240 HSTC
2008 Kubota 3240 HSTC. How do I check if FEL float detent is working? If it's not working, how do I fix it?
/ FEL float detent #2
Welcome to TBN!
If you push the joystick all the way forward you should feel it go into float and the handle should stay up on it's own. If you pick the front of the tractor up a little with the loader, it should fall if float is working.
/ FEL float detent #3
Lower bucket to ground than push joy stick all the way forward than going backwards bucket follow contour of the ground.
/ FEL float detent #4
I'll just add that you might have to do it with a quick pop flick of the wrist. that's how it works in JD. a slow push might not get it into the detent. it just a feel kind of thing.
/ FEL float detent #5
Make sure the bucket is close the ground;a hard straight push forward on the joy stick.
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
