FEL coming
/ FEL coming
Got the curl cylinder hooked up and working but haven't finished QC sub frame yet. Will ger pic's soon.
/ FEL coming #22
</font><font color="blue" class="small">( I've seen more wide front ones tipp over than I ever heard of tricycles. )</font>
Yeah, I think a wide front end does not help nearly as much as one would think. I've never seen a tractor with a sway bar so there is no roll resistance from the front until the full tilt of the front end is attained, which is probably too late to stop the momentum of a rollover. On the other hand having the pivot point a couple of feet off the ground should add some roll stability.
I think the biggest disadvantage of the tricycle gear with a loader is that all of the weight bears on one spot on the ground so you get less flotation and a greater tendency for a single obstacle or rut to spin the steering wheel out of your hands as the front turns to full lock. (Yes, I did drive an M some in my younger days.)
It's stilll a lot safer than a motorcycle....
Brad
/ FEL coming
I got to use it today even if I got quite wet as it's been raining all day. The important thing is I was able to lift dirt and rock. I also found where I need to add extra bracing and make a swap in hoses as the lift drop lever is backwards. One other thing will be changing out the vane pump for gear, to gain more lift copacity.
/ FEL coming
Been a entertaining day got cylinder lines swapped and put it to work. I was cleaning the tundra out of my 8ft x 200yd swamp all was going well untill I tried to pickup double bucket of tundra and split clevies pins mount on QC rack. I had forgot to wrap with 1/4 in. strap. O'well it was fun while it lasted.
/ FEL coming
It's repaired. here's ma shot of the upper cylinder after repair. At the top is a piece of what was there before.
/ FEL coming
Here's a shot of what I call a QC rack with small bucket hooked up.
/ FEL coming
And a shot from front.
/ FEL coming
Here's the bedrock bottomed ditch I'm using the FEL with thatch spikes to clean the tundra out of.
/ FEL coming
Here's a load of tundra I'm removing.
/ FEL coming #30
</font><font color="blue" class="small">( If it can't be altered, it ain't been built. )</font>
On the other hand , if it ain't been built , it can't be altered. /forums/images/graemlins/grin.gif Which came first ? the chicken or the egg? You do seem pretty handy tho, and do some nice ALTERING. /forums/images/graemlins/smile.gif
/ FEL coming
Here's a shot from the side.
/ FEL coming
And the last for now is from the drives perspective.
/ FEL coming
Here's a shot of the spikes without tundra.
Brady 512 Feed Wagon (A66408)
Brady 512 Feed...
2017 Ford F-150 XL (A64127)
2017 Ford F-150 XL...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
