FEL Bucket Wax
/ FEL Bucket Wax #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Has anyone heard of a "wax" or similar product that I could coat the inside of my bucket so that when I'm moving snow in the winter, the packed snow doesn't stick to the inside of the bucket causing me to only to get 1/2 scoops ??? I have heard that there is a product available but can't find anything locally.
Thanks
Eric
/ FEL Bucket Wax #2
Haven't heard of anything marketed like that, but I would think ski wax would fit the bill pretty well. It solves a similar problem.
Cliff
/ FEL Bucket Wax #3
I've heard of people using PAM (the cooking spray), but I had pretty good luck last year just having the bucket the same temp as the (outside, unheated) air. Not 100% successful, mind you, but pretty good.
/ FEL Bucket Wax #4
I just use the cheapest car wax that I can find. Remember to pay special attention to the corners where the end sheet meets the main sheet. Start with a healthy coating there first. Then work on the larger areas.
I don't even wipe the wax off when I'm done coating the inside of the bucket. I figure the more wax the better...besides, who is going to stand out in the cold and criticize your swirl marks?
The combination of the wax and a cold bucket (leave the bucket sit outside while the snow is falling) gives me great success. No sticking!
/ FEL Bucket Wax #5
Eric,
I don't know if it would work on the bucket, but I used this on my 54" mower deck from my 445. My JD dealer had a product that I believe was called Slick Coat. Farmers would use it on various equipment to lubricate and protect. It goes on as a gunmetal gray primer that is very smooth to the touch. I think it actually has Teflon material in the spray/primer.
BTW, I had my new 62" belly mower coated with a smooth Rhino lining. Works great. Wears great. Much easier cleanup.
John
/ FEL Bucket Wax #6
Eric , I use Johnsons paste wax . It holds up fairly well .
And for touch up( or lazziness ) I use PAM spray . John
/ FEL Bucket Wax #7
I would use PAM - it does wonder's on my Satellite dish to keep the wet snow off in the winter. /forums/images/graemlins/wink.gif
-Bob
/ FEL Bucket Wax #8
I use the store brand cooking spray, which is cheaper than PAM. /forums/images/graemlins/cool.gif
/ FEL Bucket Wax #9
The original name and non-JD name for the product is Slip-Plate. Lots of farm stores and TSC sell it in spray cans and also in gallons. It has a high graphite content.
/ FEL Bucket Wax #10
Hi...
Here's a link for Snow Plow Wax...
Can also be used on mower decks...
Haven't used it... so dunno' how effective it is...
A new coat of high gloss paint helps too...
Dave...
/ FEL Bucket Wax #11
I've used any of the spray-on "Instant" car waxes for years in my buckets and the undersides of the mower decks. Right now, it's Turtle Wax sitting on the shelf. Just spray a good coat on there a few times a year, and have at it.
/ FEL Bucket Wax
R-West, That's what I used last winter after my initial problem but it wasn't the answer, helped, but still had buildup. Now, the reason for the thread was, last winter my bucket was in new condition, it sure ain't now & with it being scuffed/dinged up I thought the auto car wax would be less effective than last winter. Thanks
ToAll, Thanks for your posts, appreciate your time/effort sharing your thoughts
Eric
/ FEL Bucket Wax #13
Maybe try spraying a light coat of diesel fuel on the inside of the bucket before hitting the snow banks. If it would work, keeping some in a garden sprayer would be easy, or just a bucket and a large brush or broom would work too. If it was a problem for me, I would give this a try. Inexpensive treatment if it's successful (and I only presume that it might be, but don't know how long it would last in a storm).
I have a blade, and don't have a problem with snow sticking.
2003 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2003 INTERNATIONAL...
Rears 3pt 1000 Gal Orchard Sprayer (A64911)
Rears 3pt 1000 Gal...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2007 Chevrolet C7500 Auto Crane 8406H 8,400 lb. Crane Mechanics Truck (A66736)
2007 Chevrolet...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
