FEL Bucket Hooks
/ FEL Bucket Hooks #22
Im in the prep stages right now of getting a hitch reciever welded on the top of my bucket...so I can stick a 2 x 2 in it for a light work boom pole!!
/ FEL Bucket Hooks #23
I have 3 hooks on my bucket, one in the middle, which proves handy and safer in many instances, lifting from either side or unequally raises the opposite rear wheel, as you might expect and if you raise the bucket high enough ...
just a thought
/ FEL Bucket Hooks #24
One of these days when I get around to it, I'm going to build a spill plate to go in my receivers.
/ FEL Bucket Hooks #25
<font color="blue"> Is that hook on the back bottom of the bucket? </font>
Yup, I bolted it just above the lower crease where the bucket is the strongest. I've pulled fence posts at stall speed with no ill effects. The clevis allows the hook to pivot and also makes it easily replacebale for different type hooks.
/ FEL Bucket Hooks #26
It looked like that might be where it was at but really couldn't tell for sure. If I had one there I would have the skin peeled off of my bare head. It does look like it would be a sturdy place for one.
/ FEL Bucket Hooks #27
My first post so Hi to all the clearly knowledgeable folks on this forum..
I've just made a couple of 'cheapie' FEL hooks from a piece of flat bar and thought it might interest someone.
My FEL can only lift 300 kgs (we talk metric down here in Australia) so I didn't see the need for the real 4000 kgs hooks.
I'm confident each hook will hold 150 kg.
The flat bar only needed a 10mm hole drilled then 3 drop saw cuts before welding. Hope the pic works..
/ FEL Bucket Hooks #28
Then welded onto the bucket with a MIG welder using 0.8 70s-6 wire - 130 Amps..
/ FEL Bucket Hooks #29
Ready to be painted..
/ FEL Bucket Hooks #30
John, that is innovation at its finest /forums/images/graemlins/cool.gif
They do look like they will lift 150kg/330lbs.
/ FEL Bucket Hooks #31
John,
Welcome to TBN. That is some fine looking hooks. Did you cut the slots with a mill?
/ FEL Bucket Hooks #32
Thanks Jerry! No I cut them with a 'cold cut' drop saw after I drilled the 10mm hole..
/ FEL Bucket Hooks #33
That is how I usually make slots. Welding is something that I can do, but it isn't pretty. Those are good looking welds also.
/ FEL Bucket Hooks #34
JohnF,
That is a really nice, clean job you did. I imagine it took some time to do... as nice as it turned out. Nothing like self satisfaction doing it yourself.
For those of us with less talent, there are grab hooks specifically made to weld on. They are very reasonably priced too. You can order them from AW Direct , a towing supplier. I bought 6 of them and welded them on my backhoe and FEL bucket. I've got a couple left over and may weld them on some of my implements so I can move them around (for service or adjustments) without hooking them up to the 3pt. I'll share one pic of the FEL grab hooks, one on each side. For some reason, I prefer to lift with 2 hooks always, so I don't have a center hook.
/ FEL Bucket Hooks #35
Rob, was that with your arc welder/genny at the property? Your weld looks good. The bucket weld beside it looks like they missed the mark though. By the location of the hook do you run the chain over the bucket top?
/ FEL Bucket Hooks #36
</font><font color="blue" class="small">( I too wanted the convienience of FEL hooks and read and studied etc. I got it somewhere that you can pull your FEL out of "kilter" by pulling/pushing on just one side. Mine is a little 302 so was parinoid. Is that correct you tractor vets? )</font>
G'day from Australia,
Here is our theory on the placement on the FEL bucket hooks.
If you have them too far apart, as on the pic by the dude with the chrome-pimpy, and you attach a loaded chain to one side only, you will certainly have the whole unit out of balance and will put extra pressure on the opposite seals and arms.
If you added them about 40cm to 50 cm (about 14 to 18 inches for you American dudes) either side of the centre of the bucket and used your chain as a central pivot, you then get total evenness and correct balance, which is far more safety friendly, and better for the balance.
Do we agree on this? We have set up our FEL's this way and it's mainly from a safety aspect.
hahaha.. don't forget that women think a little different to guys.
Cheers from Riccarda /forums/images/graemlins/cool.gif
/ FEL Bucket Hooks #37
Joe,
Yes, on the property...see...I'm learning from your examples. /forums/images/graemlins/cool.gif
Chain over the bucket top edge?
Yes, and no...I turn the bucket "dumped" when lifting so the chain is held only by the hooks. If I were to pivot the bucket backwards somewhat, it would run the chain over the top only when lifting dead vertical, but barely. So far I have not done that yet and that's why my top lip is not bent yet. /forums/images/graemlins/grin.gif I put them there not only for vertical lifting, but when I want to "roll" a big rock or log into the bucket.
/ FEL Bucket Hooks #38
The only place I want a hook on my FEL is in the center.
/ FEL Bucket Hooks #39
I got my tractor & loader with 400 hours on it. There was a goofy chain hook welded in the middle bottom inside bucket. Would _not_ be what I would do. It's in the way a bit for some loads.
However, I sure use the hook a lot, & a pretty good location for it when using it. /forums/images/graemlins/smile.gif
--->Paul
/ FEL Bucket Hooks #40
</font><font color="blue" class="small">( The only place I want a hook on my FEL is in the center. )</font>
i agree that the center is the best place if your gona have just one, but two hooks on the outer edges are very handy for carrying long or odd shaped objects that might try to tilt or rotate otherwise, just gota remember not to lift heavy loads off just one side
2018 Autocar ACX Xpeditor T/A New Way Side Loader Garbage Truck (A64556)
2018 Autocar ACX...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2026 VR59 59in Vibratory Roller Skid Steer Attachment (A64553)
2026 VR59 59in...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2016 Toyota Tundra Ext. Cab Pickup Truck (A64556)
2016 Toyota Tundra...
