FEL Bucket Hooks
   / FEL Bucket Hooks #11
Here are 3/8 grab hooks welded to each side of the tractor frame mounted FEL front frame. These are for pulling or for securing the tractor to a trailer when the FEL is not attached.
   / FEL Bucket Hooks #12
Don't pull your stuck tractor out using a big tractor attached to your FEL. A big tractor could bend the FEL real bad.
Three 3/8 hooks on top of a full width reinforcement.
Hooks are sloped so gravity keeps chain in the hook.
   / FEL Bucket Hooks #13
" too wanted the convienience of FEL hooks and read and studied etc. I got it somewhere that you can pull your FEL out of "kilter" by pulling/pushing on just one side. Mine is a little 302 so was paranoid. Is that correct you tractor vets? "
Yes, you could twist the loader bucket or frame. I think it would take quite a bit, however.
Using bucket hooks on a loader does require a modicum of common sense. When rigging a load to the bucket hooks, you'll want to spread the load as equally as you can.
I have three hooks welded on my bucket: one on each end, one in the middle. I use the center hook for lighter loads and a combination of both outer hooks for heavier loads. I never use just one of the outer hooks.
   / FEL Bucket Hooks #14
Cisunix-
Like JRP says, I think once you get to using those hooks, you may like grab hooks even more. You did a nice job with 'em! Also, the way you made them you could just make up another plate and weld 3/8 grab hooks then just change them out if you need to. Look at JRP's pic up close too, they do make correct hooks for this purpose, like he used on each end. I think a lot of guys may not know these hooks exist (based on many bucket hooks I have seen) so they use the S hook style and grind a big flat on them. If you get the right hook you won't have to. You're local tractor dealer should have them. Anyway, nice job!
   / FEL Bucket Hooks #15
Top view of my removable hook. I like chains too.
   / FEL Bucket Hooks #16
Bottom view with plate backing. Grade 8 bolts.
   / FEL Bucket Hooks #17
Well, since we're all sharing pics of bucket hooks, this is what I did to my MF. Center mounted using bolts and a backling plate.
   / FEL Bucket Hooks #18
<font color="blue"> Well, since we're all sharing pics of bucket hooks, this is what I did to my MF. </font>
Ok Here's mine.
   / FEL Bucket Hooks
Jerry I feel so inferior ............. I feel Like I need to get busy 'pimpin .........I really like the console I have been trying to decide how to get a radio under my canopy .........cisunix
   / FEL Bucket Hooks #20
<font color="blue"> I really like the console I have been trying to decide how to get a radio under my canopy </font>
Thanks. I thought about that one for quite a while before I built it. I wanted to just do it once and have everything that I would ever need. Even though, I do have room for other things should I ever want an addition. I didn't think about it until I looked at the pictures this morning, but I didn't put up pictures of the console top. It slides open for servicing and has a spring-loaded latch. I'll take some pictures when the weather gets better.
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A51039)
Hay Van FL-95 Bale...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
VERMEER RTX450 (A50854)
VERMEER RTX450...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
