Front-End Loader FEL Bucket Extension
/ FEL Bucket Extension #1
NonTypicalCPA
SW Michigan
Kubota L3940
I'm looking for a way to increase the amount of firewood I can load into my fel bucket. I want to cut down on the number of trips to the trailer. I have seen in a previous post where someone on here made one, but I don't have the tools or welding skills to make my own. Does anyone know of any products manufactured for sale that would work for what I want to do?
/ FEL Bucket Extension #2
Sorry, but I don't. But have you looked into just buying a larger bucket to fit you loader? Don't know your brand of machine, but a lot of FEL's come with a standard size bucket, with options for a larger or more heavy duty bucket. Also if you have a universal mount on our FEL you may be able to look at different manufacturers buckets as well. That might be easier than trying to fab something.
A different approach might be to use a trailer of some kind that you could load more into than your bucket would hold. Or possibly add a carry all to your 3 point hitch than you could load both the loader and the carry all. Just a thought.
/ FEL Bucket Extension #3
Maybe a sheet of plywood attached with clamps on bottom and sides.
/ FEL Bucket Extension #4
How about clamp on pallet forks, an old pallet with sides made from plywood. No welding required.
/ FEL Bucket Extension #5
Now, add a pallet carrier to the three-point, similarly outfitted and you have a two-fer
/ FEL Bucket Extension #6
How about making a carryall for the back? Search on carryall and you'll find tons of variations.
/ FEL Bucket Extension #7
build a box from plywood and 2x4s that fits in your bucket -- clamp it in some way - and haul away.
/ FEL Bucket Extension #8
Cut a piece of ply thats size of the base of the bucket plus a couple of feet. (Say 4' x 4' ). Then string chains or cable from the front corners of the ply to the top corners of the bucket. (You may have to drill a couple of holes in the top corners of the bucket to attach some shackles.) A couple of small cheap 'G' clamps may also be needed to keep the ply in position. You should be able to knock something like that together in a couple of hours, and attach and remove it in seconds when necessary.
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
WOODS 8' HYD TILT BLADE, 3PT (A63290)
WOODS 8' HYD TILT...
Gooseneck Stock Trailer (A64047)
Gooseneck Stock...
2014 WINPOWER DR2014-AAMTJ GENERATOR (A59910)
2014 WINPOWER...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
