FEL Boom Pole - Lift ?
   / FEL Boom Pole - Lift ? #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Wondering if anybody has made one that can give me some direction. I am in the process of adding forks to my FEL. I have the frame and quick attach / detach system worked out for the forks. I can use same frame but need to add a pole to lift higher. What I need to do is lift about 16 feet. Loads will be light. Need help with the geometry of this thing. Did a search but found nothing helpful. Going on a M5700.
thanks
   / FEL Boom Pole - Lift ? #2
There is a reference to a fel boom pole on one of the pole barn threads. If I recall the guy adapted a 3pr hitch to his fel and hooked it that way. I have also seen a boom pole, with the rear end made of channel that the forks just slide into. Seems like the fastest way to do it to me.
   / FEL Boom Pole - Lift ? #3
I posted my boom pole project in Boom Pole for QuikTach and Three Point Hitch. In one of the replies it was suggested that the angle iron was not adequate for the supports, and after a few days use I must agree. I will probably be substituting some 2" pipe for the angle iron supports.
   / FEL Boom Pole - Lift ? #4
Some scrap 3" I-beam and box to fit your forks make a simple boom pole.
   / FEL Boom Pole - Lift ? #5
Number #2
   / FEL Boom Pole - Lift ? #6
Last one
   / FEL Boom Pole - Lift ? #7
The box is 4' and the I-beam is 10'. On my tractor (Branson 2810) max height is 19' 6" (3' off front bumper) 16' (6'8") and 12' (11'4").
   / FEL Boom Pole - Lift ? #8
This is mine, see attached. It is made at Quality Welding. http://www.qualityweldingservice.com/liftboom.html
Very handy nice and It will reach about 20’. You have to be careful if you put a lot of weight on it … you also have to put a lot of rear weight. KennyV.
   / FEL Boom Pole - Lift ? #9
Kenny,
I like your design. It looks like a factory job. How high does it lift?
   / FEL Boom Pole - Lift ? #10
Here is a picture of one I just made to lift the trusses up on a new building. Made out of 3' square for the frame and 2: for the pole.
Works pretty good but is a pain to change, wish I had a quick attach
Guy
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
