FEL boom, no welding
/ FEL boom, no welding #1
gocards1177
Rolla, MO
Just playing on Ebay and doing something thinking. It seems to me that with one of these:
60" John Deere Pallet Fork Attachment Global Euro Style Coupler Loaders Deer | eBay
and one of these:
Trailer Hitch Receiver for Pallet Fork Forks Lift Forklift Skid Steer PFRH | eBay
plus a length of 2" square tubing, some cables for bracing, and necessary hardware, one could make a very serviceable boom for their FEL. Am I missing anything? Other than 18" and $90 is there a huge difference between 42" pallet forks and 60" pallet forks?
No one? I guess I'll just give it a go and report back.
/ FEL boom, no welding #3
and one of these:
The problem I see with 60" pallet forks is if you fully engage a pallet the forks will extend beyond the pallet. Depending what is beyond the pallet, that could be a problem. Up set the next pallet when you lift, fork holes thru a pole barn wall, etc. I would want 48" forks.
I'm glade you pointed that out! I was thinking the 60" referred to width. That makes more sense. I would be using it for moving normal sized pallets and general brush moving, so I'll go with 48#'s. I'm going to place and order on that and the adapter today and see if I can cobble together a boom of some sort. Thanks!
/ FEL boom, no welding #5
I have 60" length of forks on my 4020 90 HP tractor, there great for moving round bales, which is the main use of them for me, but there are a pain when dealing with pallets as they will go through or beyond the pallet, the second thing is when dealing with a heavy pallet, out on the end of 60" forks can be fun as well, as it puts an extreme load on the front axel and I have small cylinders on the bucket and use them to gauge the "over weight of the load, a load on the end of the forks many times will load out the cylinders on the bucket but all the way back they will handle it,
there is a place for the long forks and there is disadvantages as well,
/ FEL boom, no welding #6
Do you need some way to hold the forks down, beside the weight of the boom and load? My forks can swing up unimpeded, a pain sometimes. I would think the less slip the better if you're trying to place something accurately. Otherwise, let us know how it goes!
Jim
/ FEL boom, no welding #7
Slop, I (thought I) typed, less SLOP
Jim
2013 PETERBILT 587 DOUBLE SLEEPER ROAD TRACTOR (A60430)
2013 PETERBILT 587...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61306)
1992 Talbert 70...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2007 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A60429)
2007 KOMATSU GALEO...
