FEL Attachment (3 point)
/ FEL Attachment (3 point) #1
Skycop
I need some help from you guys. I have a 3400 and am looking for the name of an attachment that goes on the front of the FEL that you can hook up 3 point attachments to.
I saw a pic on here but can't find it, A guy had a landscape rake on his FEL and used it for pushing up small brush.
Thanks for the help,
Tom
/ FEL Attachment (3 point) #2
I'm not sure I've ever seen one.. but can inagine that you could take a quick hitch, and fab a bracket to the back of it that bolted on to your bucket.. etc..
If there is a comercial one out there.. I'm sure someone will post info on it soon enough. Sorry wasn't more help..
Soundguy
Thanks, ye With all the information floating around here it will turn up...
Tom
/ FEL Attachment (3 point) #4
I've seen QA plates used to mount 3pt stuff and they are run hydraulically. BUT, only on skid steers. Maybe check out the local bob cat store?
jb
/ FEL Attachment (3 point) #6
PineRidge said:
ATI has them, check page 31 adapter
Hmm.. the only ones I saw were for skid steers.
Did i miss something?
Soundguy
/ FEL Attachment (3 point) #7
What I saw said custom built so I'm assuming they can be made to fit your piece of equipment. I guess a phone call would verify that.
/ FEL Attachment (3 point) #8
Soundguy
If you want something for an FEL, it's gonna be in the skid steer attachments most likely because many tractors have universal "skid steer" quick attach brackets like New Holland puts on their tractors.
The Universal adapter from ATI is a little heavy at 195 lb, but it has the added feature of sliding (adjustable) category 1 links. That's a great feature, because many implement manufacturers do not stick to the exact Cat. 1 dimensions. My NH 3PH adapter for my FEL is not adjustable and about half my implements won't fit on it just for that reason. On the bright side, it was only $250 and very well built. I'm not sure what the ATI adapter is, but I'd bet it will be up around $400...just a guess.
/ FEL Attachment (3 point) #9
Hmm.. think they will fit my loader (GRIN)
Soundguy
I would hate to get one and it not work with all the attachments. I might make some phone calls to see.
/ FEL Attachment (3 point) #11
Wow! The Ford single arm loader. I have not seen one of those in years. Used to trade them in back in the '70s. Unfortunately back then, most were cut up for scrap iron. Probably should have saved them.
OrangeGuy
/ FEL Attachment (3 point) #12
OrangeGuy
Yep ford made a 711 and 722 1-arm loader. Either could be had with trip bucket or hyd dump. 722 had the hydro sump in the loader body and was sold with it's own spool set and hyd pump.
My laoder is a 722 with hyd dump, however the oem spool set and pump have long since died, and the loader is plumbed off tractor hyds via 2 spools on the hyd top cover.. works fine. The sump has a couple pipe plugs in itto keep it clean.
Decent little loader.
I've seen 2 others liek it, plus a different make on an IH cub once.
Soundguy
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2016 Bobcat E50 (A64126)
2016 Bobcat E50...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
