Favorite Gloves?
/ Favorite Gloves? #1
mason leah
NJ
Kubota
I'm starting to feel like I have unusual hands compared to most welders, I don't have baby hands, I usually measure for at least a large according to most MFG's palm measurement guides but I don't have big sausage fingers. So I generally either get a whole lot of loose material around the fingers or a glove that catches at my finger tips and restricts movement quite a bit, often both. I've generally used the Hobart premium mig/Kontour gloves you can get at Tractor Supply. I tried the higher end Lincoln gloves you can find at Home Depot, and they were just made for someone with a whole lot shorter and fatter fingers than I have, I thought they would break in some but the stitching is just ripping out and they're getting slightly stiffer the more heat they're exposed to. So I'm looking for new gloves.
Have you guys found any that you prefer far above other gloves?
/ Favorite Gloves? #2
I have fat hands & short, normal sized fingers. I had a custom made pair. Whites in Spokane, WA.
They fit like a second skin - elk skin. But so damn expensive - only use when driving my truck.
Otherwise - Aerostich ropers work pretty well for me.
/ Favorite Gloves? #4
I’ve worn Yellowstone Elkskin gloves for over forty years. I think they are the best available. Many options to choose from - just use the pull down menu.
Home - Yellowstone Gloves
/ Favorite Gloves? #5
I use the DEKO Welding Gloves mostly, which i got for around $12.
These leather gloves are the best tig welding gloves. They’re flexible, lightweight, and breathable – while also protecting your hands and forearms from shrapnel and heat.
/ Favorite Gloves? #6
Most comfortable I have ever worn and durable. https://www.amazon.com/gp/product/B...&linkId=3fa6d56aaa5286a4cca7b7f234042748&th=1
/ Favorite Gloves? #7
Boss, bought at Southern States. Protect about half way up the lower arm.
/ Favorite Gloves? #8
For MIG work, unlined Black Stallion Mighty Migs. Can choose material, pig/cow sometimes deer skin. Prefer unlined gloves for the added flex. Good longevity to price ratio. For TIG a thin pair of deerskins.
/ Favorite Gloves? #9
I really like Tillman welding gloves. It used to be that gloves, no matter which brand as long as they were high quality, were all the same fit for a particular size. But now it seems like there is a lot of variability in fit. So I go to the welding supply store and try on several glove pairs of the same size to find the best fitting ones. With the Tillman gloves I can always find a few pair that fit perfectly. I use pig and deerskin gloves. The deerskin gloves are perfect for TIG welding small and delicate parts.
Eric
/ Favorite Gloves? #10
I know what you mean. I'm real picky on my gloves. My hands are pretty much average - not fat or skinny fingers - but the overall size is always a surprise, being between XL and XXL.
Like etpm says I go to a store I now of that has lots of gloves and I'll try on every single pair because they do vary. I want them to be thin leather, perfect fit, and pig or goat leather. Sometimes deerskin. I've got a pair of Yellowstone elk, but they are a little too thick for what I like in a glove. Nice quality, though.
Although I've got several pairs of welding gloves I never use them. Instead I use the thin pigskin and goatskin driving gloves from a men's store.
rScotty
/ Favorite Gloves? #11
I used to do production welding in a factory. If I was stick welding I would use thin deerskin type gloves. Tried all kinds. I prefer the short cuff regular work style glove, thin supple leather. I have these below from Sam's I use them for everything. Tillman Tig gloves are also pretty good. I value dexterity and ergonomics over heat abatement. Just keep you hand away from the fire!
For a lot of Mig welding where I had to have my hand down to guide, I would use a right hand like the picture below and what you would think of as a typical thick, long welding glove on my left. For just a little Mig, I would still wear a pair like below. But if you gotta have your hand by the fire you will get sparks down into the cuff, plan accordingly.
I have only run about 10 feet of bead with Tig and maybe a couple dozen yards of acetylene but for both I used gloves like below.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
Ford 3 Point Bucket Scoop (A62613)
Ford 3 Point...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
