faulty hydro drive
/ faulty hydro drive #1
redliner
Kubota B2150 HST
Hi, i have a b2150 HST that has developed a problem with the hydrostatic drive. has anyone split one of these tractors.
/ faulty hydro drive #2
What problem do you have with the hydro?
The 50 series had a well made hydro (Daikin, I think) but it is now approaching 30 years old so it may me time for a set of valve plates.
Before you gut it, I would suggest you have the local dealer or someone who know what they are doing to run some pressure tests on the charge pump and the drive pressure. It could be a charge regulator issue or a high pressure relief valve if either pressures are found to be low.
Good luck!
YC
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
Big John Semi Trailer (A65640)
Big John Semi...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
