Fault codes
/ Fault codes #1
Normando1
John deer 310sg
F460 fault code John deer 310sg
/ Fault codes #2
That code is: "Input air temperature reads low."
I believe that this is one of the inputs to your Engine Control Computer (the ECU). It could be a bad temperature sensor or a broken wire between sensor and computer.
But it could also indicate a problem with the computer module itself. ECUs are a known trouble component. The frame mounted ECUs get a lot of engine heat and water & end up leaking or swelling up and breaking their internal printed ciruit.
Non-repairable. Replace with new.
I just had the ECU replaced on our 310SG. My error code was coolant temperature instead of air.
rScotty
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
