MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,246
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Lime away seems to work better for lime removal in my opinion.
Okay, I thought he said it was Calcium.Lime away seems to work better for lime removal in my opinion.
220, 221, whatever it takes.Okay, I thought he said it was Calcium.
Like he said.Both CLR and Lime-Away will go after any imperfection in the metal of the aerator or faucet, so I would not overfill the baggie. In my experience, that method hasn't saved very many aerators, and it has killed a few faucets for me. A bit of judicious heat works better for me, bearing in mind that aerators tend to be very thin metal, with plastic insides, so I think it is not advisable to go wild with a blow torch.
Lime deposits are calcium deposits, calcium carbonate. Hard water deposits may include magnesium sulfate and carbonate, as well as calcium sulfate and carbonate. Only the carbonates are dissolvable in acids, such as CLR, lime-away, or citric acid. If you are unlucky enough to get magnesium oxide deposits, it is not going anywhere, ever.
All the best,
Peter
I've never tried a torch on an aerator. Like mentioned, most are now plastic inside, plus rubber washer(s). Plus many low-end faucets are sometimes chromed plastic.Both CLR and Lime-Away will go after any imperfection in the metal of the aerator or faucet, so I would not overfill the baggie. In my experience, that method hasn't saved very many aerators, and it has killed a few faucets for me. A bit of judicious heat works better for me, bearing in mind that aerators tend to be very thin metal, with plastic insides, so I think it is not advisable to go wild with a blow torch.
All the best,
Peter
Or CLR…might not even have to remove if blockage dissolves…White vinegar in a plastic baggy held on with a rubber band over night will dissolve the calcium.
If not, channel locks and replace as stated above.
