Farmtrac filters
/ Farmtrac filters #1
sbrace
Texas
Farmtrac 555, 50 Farmall H, 49 Ford 8N
Would someone be so kind to give me the Farmtrac 555 filter numbers or after market numbers for fuel, air, eng oil and hyd.
/ Farmtrac filters #2
i have no idea what those numbers might be, but have you tried a place like napa? a lot of times they can cross referce and have the filter neede. just a thought.
/ Farmtrac filters #3
engine 1515
Which hyd pump do you have the one mounted on the back of the engine or the front left
it makes a differance
front pump 1715
rear 1515
are you fuel filters spin on or cartrige.
I don't have these in front of mebut will get them monday
/ Farmtrac filters #4
On my Farmtrac 545, the air filter elements have Ford part numbers on them that interchange to NAPA 2533 and 6523. The oil filter seems to be NAPA 1452 but there are several numbers which will work. Except for the fuel filters, all seem to be the same as a Ford 3910 or 3930. Mine has (2) spin on fuel filters that I have not been able to interchange. One note, the engine oil filter did not have enough thread engagement until I found out the nipple the filter screwed onto was not bottomed and would screw in too deep. I Loc-tited it at the proper stick-out.
Tom W.
/ Farmtrac filters
Thank you all for your help.
Scott
/ Farmtrac filters #7
Not 100% sure but tryESL-15328 fuel filter-Wix33472
ESL-10221 Air filter--Wix42533
ESL-10222 Air filter--Wix46534
ESL-10083 oil filter--Wix51515
ESL-11255 hyd filter-Wix-51712
hope this helps.
/ Farmtrac filters #8
Does anyone that reads these Farmtrac threads have an "IN" with someone that works for Donaldson or Wix??? We are a Farmtrac dealer (please don't laugh or run away :D) and are having trouble crossing over filters that fit the tractors. I wish that the filter dealer sites would list Farmtrac, Escort, LS Cable, etc. They sure could be getting alot of business from dealers in search of filters!!! Hint, hint, hint!;) Thanks!
/ Farmtrac filters #9
I am glad I am not an idiot. I looked all around trying to cross ref filters for my 270DTC and couldn't find any numbers. If you find the numbers can you post them here?
/ Farmtrac filters #10
Eric,
If I am not mistaken the 270DTC runs a Daedong engine, and I believe a NAPA Gold1324 filter will fit the engine. I hope this helps.
/ Farmtrac filters #11
The filter manufacturers have websites. I never received a reply from Wix, but I received one from Baldwin saying they had not had enough requests to do crossovers from Farmtrac. Some more requests to their website, or to gjohnikins@baldwinfilter.com or to Gina Johnikins at 1-800-822-5394 would show some interest. Give them a call or email.
Tom W
/ Farmtrac filters #12
I had the same response from WIX which was none. I will send emails and calls. Thanks for the info!!
