FarmTrac DTC 360 Clutch Problems - Please Help
/ FarmTrac DTC 360 Clutch Problems - Please Help #1
Qapla
Veteran Member
Gator Country
New Holland TC40D HST 4WD FEL/BH
Our 360 has the Backhoe/Front Loader attachments. This is our primary use for the tractor. It has been working quite fine until Yesterday.
It was used the day before and was evidently working normal (my brother was using it). Then I went to use it the next morning. There were problems:
The clutch pedal seems to have no real resistance now (almost like stepping on a wet sponge)
The tractor has no "get-up-and-go" in the upper range.
The mid and lower range seem to still work as before, however the clutch still has no real resistance at the pedal as before. Lately the mid-ragne is starting to lose power when the loader is fully loaded or I am trying to push a large amount of dirt.
Someone suggested I check the return spring. It seens to be just fine.
Any ideas?
Does anyone know where to get a service/repair manual for this tractor?
/ FarmTrac DTC 360 Clutch Problems - Please Help #2
I sent you a Private Message.
/ FarmTrac DTC 360 Clutch Problems - Please Help #3
Does the Back Hoe attach to a sub-frame or just connected to tractor with 3pt hitch? If no sub-frame, you need to check all the bolts that hold the tractor together around the transmission. No sub-frame can cause bolts to loosen and brake. Be sure and check hydro fluid level and check for leaks.
I have a LongTrac (Long Agrabusiness) and ordered a shop manual, I think it was around $120.00 for the manual. I ordered it from Long dealer parts counter guy.
Does the Back Hoe attach to a sub-frame or just connected to tractor with 3pt hitch? ..... Be sure and check hydro fluid level and check for leaks.
The backhoe and the FEL are part of the Farmtrac package, It came complete with a quick change sub-frame system. I checked all the bolts while I was looking for any missing springs.
All the fluid levels seem OK.
/ FarmTrac DTC 360 Clutch Problems - Please Help #5
It sounds like a possible clutch failure. You may have to split the machine to repair.
jb
/ FarmTrac DTC 360 Clutch Problems - Please Help #6
Was the manual helpful? I am trying to split one and it's not wanting to come apart
/ FarmTrac DTC 360 Clutch Problems - Please Help #7
I'm having the same problem with clutch on my Farmtrac 360 DTC. What ended up being the problem/solution with yours? Any help you can provide would be most appreciated. Thanks!
/ FarmTrac DTC 360 Clutch Problems - Please Help #8
Throw out bearing?
